Panasonic HS2 Upgrade
Discussion in 'Blu-ray & DVD Players & Recorders' started by THX THX THX, Oct 12, 2003.
  1. THX THX THX
    THX THX THX
    Bad trader
    Oct 11, 2003
    301
    16
    Lincs
    Does anyone know if it is possible to upgrade the 40gb hard disk inside a panasonic HS2?
    Any info would be much appreciated.
    THX THX THX
  2. CARLOS
    CARLOS
    Feb 11, 2001
    5,997
    WEST MIDLANDS
    +1,226
    You can change it to a bigger unit but unfortunately it still only uses 40gb capacity which is all the internal hardware allows.
  3. THX THX THX
    THX THX THX
    Bad trader
    Oct 11, 2003
    301
    16
    Lincs
    Thanks,
    Shame! Is it possible to upgrade the firmware on the unit to accept a bigger drive?
    THX THX THX
  4. CARLOS
    CARLOS
    Feb 11, 2001
    5,997
    WEST MIDLANDS
    +1,226
    I don`t believe so :(
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Only if you live in japan, and are prepared to pay panasonic to upgrade it for you. They won't do it on any other countries models, and no one has been able to find a way round the problem of getting the extra disc space to be seen by the machine.
