Panasonic HS2 - TV interface problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by Simon_DH, Jun 19, 2004.
  1. Simon_DH
    Simon_DH
    Hi there, hope the forum can help me out.
    I've got a Panasonic HS2 recorder hooked up to a Panasonic TX28DT4 iDTV with an NTL box in there as well. Current connections are Av1 from HS2 to AV1 on the TV and the 1st NTL output to AV2 on the HS2 and the 2nd output from the NTL box direct to AV2 on the TV.
    Most of the time things are OK and I can record off either source and watch the other But.... when bringing up the menu on the HS2 or dubbing (which leaves a message up on the screen) I get the HS2 menu screen (or the dubbing message) up on both AV1 and AV2 on the TV which means no NTL while dubbing.
    Is there something I've not get set up correctly ?
    Simon
