Panasonic HS2 output
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lumox, Dec 18, 2006.
  1. Lumox
    Lumox
    Does anyone know if I could output dvd to a pc from an Panasonic HS2.
    If I can, could you give a short description of how please.
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,830
    +3,195
  3. Lumox
    Lumox
    Can I output directly to pc with a cable or scart connection, without having to copy everything to disc first.
  4. marty2005
    marty2005
    Jul 22, 2005
    3,694
    Great Yarmouth
    +155
    you could do that if you have a capture card but it would be a lot slower since it would be in real time. TV cards have svhs in. If your dvd has svhs out use a svhs cable, if not a scart to svhs cable.
    A two hour movie would take two hours to capture. Burn to disk and copy to pc would be a lot faster.
  5. Hal_loe
    Hal_loe
    Aug 1, 2006
    1,160
    63
    +118
    They only way to maintain the quality as it is on the recorder is to transfer to disc and then copy onto the PC.
    I do this with DVD-RAM as you can re-use the disc lots of time.
  6. Lumox
    Lumox
    What about using a bigger hard drive in the HS2, can this be done?
    Thanks for your help
  7. Hal_loe
    Hal_loe
    Aug 1, 2006
    1,160
    63
    +118
    No Panasonic DVD Recorders cannot have the hard drive upgraded the size is locked in the firmware.
  8. Lumox
    Lumox
    Gutted. Thank you :(
  9. nwgarratt
    nwgarratt
    May 5, 2002
    27,830
    +3,195
    To extend Hal_loe's reply. The hard disk can be replaced by another and even a bigger one but, 40GB is what will be recognised. You could put a 120GB in their but it will be shown as 40GB.
