kenfowler3966
I have an rf set up in my house that allows all the outputs from the various equipment in the lounge to be seen on all the other tv's in the various rooms.
I have bought a wireless gadget that allows all the equipment to be controlled with their original remotes from whichever room is in use. This works by receiving from the remote, transmitting to the unit in the lounge which then repeats the signal received, and when pointed at the units works fine. However for a neater installation it comes with a cable and small IR sources which stick over the IR receivers on the individual units. This works great for the digibox and the freeview box, but I cant locate the IR receiver on the front of the HS2. I have tried the small IR source over every part of the front of the unit with no luck and the input is not obvious anywhere.
If anyone knows exactly where it is can they let me know please.
