Panasonic HS2 & FR recoding mode
Discussion in 'Blu-ray & DVD Players & Recorders' started by TP2K, Apr 25, 2004.
  1. TP2K
    TP2K
    Nov 14, 2002
    523
    16
    - having created several -R discs recently using the FR mode for stuff which exceeds the standard XP vs disc space.
    I have noticed when looking at the properties via a PC, that the discs are only infact 3.95GB used.
    Is this normal?
    I assume it is, and if it is then it's a great waste of space on recordable discs which could be beter utilised into providing better PQ.
  2. lovemovies
    lovemovies
    Mar 3, 2003
    231
    United Kingdom
    +5
    Iv'e noticed that mine used 4.1Gb. Strange.
  3. pinatubo
    pinatubo
    I believe the 4.1GB size is the maximum indivudual file size in the DVD -R file specification although the disk can actually hold 4.38GB.
    Authoring software such as Movifactory 2 from Ulead will , if the recording exceeds 4.1GB , generate a second contiguous file to make up the difference.
  4. nwgarratt
    nwgarratt
    May 5, 2002
    26,443
    +2,871
    I noticed the same thing. RAM also has an average 4GB limit
    I now record everything at least in SP mode and then edit on the computer. This is so I can use the full capacity of a +R/+RW.
    I use a combination of DVD Author, MPEG2VCR and DVD2DVD-R to get the best results.
