Panasonic Hrm-e50 Problem With New Ram Discs Activating Disc Protection Lock
Discussion in 'Blu-ray & DVD Players & Recorders' started by CARBON, Jul 29, 2005.
  1. CARBON
    CARBON
    Hi All Beggining to think I have a problem with my E50. I just bought some new (10) Panasonic DVD-Ram discs and my less than 1 year old (new bought off ebay) E50 will not read the discs. Just keeps coming up this disc is protected and won't record. This is on all 10 new discs! I tried in the menu removing the lock but it will not activate the lock off setting. Anybody got any suggestions? This has me baffled as all my other DVD-Ram discs (except one which does the same thing) - work fine. As do DVD-R discs. I say work fine but I have the same freeze ups and other error problems ocassionaly I see in the forum about the E50.
    Dave.
  2. mentsugi
    mentsugi
    Oct 2, 2002
    385
    +24
    Not sure if this is helpfull to you but I had exactly the same problem with my new ES20D except that it only happened with my old Panny DVD-RAM that had been used in my previous Panny E30. Any new Panny DVD-RAM I bought recently works fine but the older -RAM would lock and I could not unlock or format???
    The only workaround I found was turning the 1second record function to OFF and then I could format the disk and all is well. However your model does not have this function.
    What is does highlight is that there may be some slight differences between the old version/vintage DVD-RAM and the new version DVD-RAM that the recorders do not like? :confused:
  3. ptek
    ptek
    Cartridge type or loose ?, if cartridge type (ie, in a carrier), these have a record prevention TAB slide, also, feeler arm finger that detects this TAB may be sticking and E50 detects wrong info.
    You may also require the latest firmware, but that should not be a problem with your RAM disc, worst case, actual drive may be tired and require replacement, if it is, you may as well buy a new unit instead.
  4. CARBON
    CARBON
    Thanks for the response. Can't believe that it is wearing out at only 8 months or so old?
    The discs are the single type not in a caddy. Interestingly I tried several of the discs I had bought that failed to work 24 hours later and managed to get three out of the ten that previously failed before to work!
    Once I had them working and recorded some material on them. They have given no more problems.
    One other disc looked as though it would work but eventually came up "record failure" or similar and the machine just went into a lengthy tizzy before it would let me get the disc out. I will try the failures again before I take the back to see what happens.
    Could the manufacture of the discs be less than accurate and thus outside the paremeter that the machine will read? I have never had a problem with dvd-r discs except datarite red ones. A big load of beer mats out of the 50 I bought.
    I would like to try another make of dvd-ram discs other than panasonic to see how they perform. Any reccomedations on make welcome.
    Thanks,
    Dave.
  5. norfred
    norfred
    May 2, 2004
    289
    bromley
    +9
    I have used Smartbuy from UKDVDR with 100% success in eh50 e85 e50 as well as ram drives on the PC. Other suppliers stock these too
    norfred
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    Sounds more like a problem with the E50 rather than the discs - it could be you need a lens cleaner (this for example).
  7. ptek
    ptek
    If you have problems with Panny RAM disc, don't bother trying other makes, unless the disc's have been mishandled with finger prints, etc, sounds like drive problem, and yes, try cleaning OPU objective lens first with DVD cleaning disc.
  8. Aladdin
    Aladdin
    Mar 25, 2003
    25
    From UK but working in Germany
    Hi Carbon,
    Did you get a solution to this? My E50 has just started doing this, that is, telling me that the RAM disk is protected when it isn't.
  9. illustrator
    illustrator
    had this problem with dirty discs, a quick wipe with a duster & problem sorted, but as the discs are new it may be the ram drive thats the problem. i'd go with the lens cleaner as Rasczak suggested
  10. Jona
    Jona
    Mar 4, 2003
    38
    Milton Keynes
    I have just recently received some non-caddy disks that I requested from the Panasonic eshop site. I have exactly the same problem and do NOT believe that my E50 recorder is faulty. I can only think that there is some incompatibility issue somewhere. The new disks say '3x speed on them' - not sure my older 'caddy' types were the same rating. I think we need to get Panasonic to comment on this. Seems crazy having bought supplies from same company as the recorder that they don't work together!
  11. HMHB
    HMHB
    Nov 11, 2001
    25,514
    Nottinghamshire
    +3,851
    I always buy Ridisc green Ram DVDs from SVP and haven't had a problem at all so far with them :)
  12. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +297
    There is a posting somewhere on these forums regarding contact with Panasonic on this and the reply from Panasonic was to use Maxell discs!
    Do as JohnG says and use the Ridisc from SVP. I have some of these and they always work OK.
  13. Jona
    Jona
    Mar 4, 2003
    38
    Milton Keynes
    Thanks for the tip Royold. Have used SVP before and was happy with them. I only bought direct from panasonic on this occasion as I thought it would avoid compatibilty problems!:suicide:
