Panasonic HDD query?
Discussion in 'Blu-ray & DVD Players & Recorders' started by StevieC, Dec 4, 2004.
  1. StevieC
    StevieC
    What is the HDD advantage of the Panasonic E85 over the E55 which doesn't have a HDD??
    I was going to go for the Panasonic SC-HT25R package but wondered what advantages/features I would get if I paid the extra £300 for the SC-HT37R package?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    There are several benefits:
    1) You record onto the HDD (and thus have all the DVD-RAM like features of editting, playlists and timeslip) but can still dub to highly compatible DVD-R.
    2) Due to the larger capacity you can record in the highest possible quality onto the HDD, edit and then dub to DVD-R with the maximum possible bitrate given the running time of your editted recording.
    3) No need to hunt around for disks
  3. StevieC
    StevieC
    So with the E55 I can edit recordings on the DVD-RAM but once edited I have no way of transferring it to the cheaper DVD-R so therefore have to spend more on DVD-RAM disks?
    Could I use a PC to transfer from DVD-RAM to DVD-R .. or is this too much of a long route for a shortcut?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    Yes - see the sticky thread at the top of this forum - PC GUIDE: DVD-RAM To DVD-R".
