Question Panasonic HC-VXF990 Quality Issues
TM19
I hope someone can help?
I’m a video novice using a 4K Panasonic HC-VXF990 camcorder to do some music videos and the quality is great when I watch them via my TV but I’m disappointed with the quality when ;
1) I see them shown on Spotlight TV (Country Music Channel on Sky-Not HD)
2) When I burn them to DVD.
Not sure if I’m doing something wrong or if I just need to upgrade my camera?
I record and edit in 4K using Power Director and send to Spotlight TV In MPEG4 format, you can check out the quality of one of my videos at
Hopefully I have given enough information and I hope someone can help me.
Thanks in advance 🙏
eMeS
I've owned and used a VXF990 for a short time, but so far haven't managed to see any of my footage on a 4K display.
There's a massive difference between the overall data rates between 4K and the earlier AVCHD standard. Purely as a diagnostic aid, can I suggest you try recording in AVCHD and see whether your software can cope properly with a reduced video bandwidth. I know this won't give you 4K at the end for display, but if the sound is OK, it might be a clue as to where to look next.
Best Wishes
Upvote 0
chrishull3
Thanks in advance 🙏
Your youtube is on as HD and it does not look bad, DVD is only SD and i suspect the tv channel is also sd so the quality will be a lot lower,if you are happy with the direct results from your tv the camcorder is cetainly not the problem.
Upvote 0
TM19
Best Wishes
Thanks for replying, sorry but I'm just not sure what angle you are coming from?
Upvote 0
TM19
Hi Chris, thanks for your reply. Yes the channel is SD. If I can be more specific, check video at about 25secs and look at the guitar strings, out of focus?
Upvote 0
12harry
May I? - Burning to DVD quality is way off from your 4K - You can get better play-quality by editing to USB-Stick - a good step-up from DVD and in my experience, a lot easier to do.... the snag being USB sticks are more expensive if being "Given away" - Blueray discs will be cheaper than USB but there's less choice in Burning software and you need a BD-Burner+Player obviously.
Whenever media is changed from one standard to another there is some loss, unless the pixels are an exact multiple - the same goes for frame-rate issues. . . . and Audio formats.
However, it should be the Content that shines through,. . . . . although it's good to plan for the average viewer's set-up.... which may be far less than the camcorder you chose. This will apply to the Vision as well as speakers.
Good Luck.
Upvote 0
