Noble372
I am one of the few who have a tv and 4k player that support both formats, Some 4k blu rays i have support both formats, I usually go with DV though it from a technical point, It is the better format, But i have to disable HDR10+ on my UB820 otherwise it shall always default to 10+ instead of DV, Any way around this without turning 10+ off on the player? The only 4k Blu ray i have that support only 10+ Is the cornetto trilogy, Any one else in a similar situation which format do you choose??
