Panasonic GZ OLED Series Owners Thread
giovvanie
Definitely better writing in your one as well.
Have to say Fall Guys does look amazingly bright and colourful on my GZ. And that’s in Pro 1 :)
Lancia are you so limited or you can’t read ?
Dynamic on default settings is awful in HDR , i recommend only Dynamic if you follow my settings .
Lancia34
Wow, nice guy and no thank you I won’t be using your settings as I’m not blind :smashin:
Lancia34
I’m a nice guy indeed , i just love poeple like you , dislike without checking.
But there's no need to go near dynamic as the best most natural picture settings are via the Pro modes for both SDR and HDR. OOTB they are stunning but once calibrated even better but it's Pro1/2 that give the best picture and no need to go messing with other presets.
Anyway, can probably put this to bed now and move on ;)
dion 6
Tired to use the amazon prime app tonight and it was frozen on the prime logo would not load switched off and on a number of times and would not work gave up and used my 4k firestick to be honest I prefer the firestick is this just a clich or have any of you had the same problem
Lancia34
Zombie Twin
TV finally up on the wall. Well, after lots of screaming, shouting and crushed fingers.
Topped off with a large, custom-printed poster I've wanted for ages, and was the kick I needed to get it done.
Plumbing in was a pain, as wanted all the wires hidden. Too knackered to enjoy it at the moment!!!
Zombie Twin
Looks great. The hard work really payed off
Thanks!
There is a wire by the centre speaker to be hidden and the trunking you see will be gone, too, so it all becomes a case of 'more posters, more shelves for collectables' and full stream ahead!
Watched Halloween II in there earlier, and - as planned - once everything is shut, there is absolutely no light, no reflections or other distractions. Absolute bliss!! :)
markreed89
Hey guys, just wondering what gamut youtube hdr is encoded in? The gamut doesn't change automatically from rec 709 to 2020 like it does with any other hdr content. Howethet the brightness etc does go up too 100 as expected. Do we need to change gamut manually?
Tommo79
Set it to Professional 2, Warm 2, everything else to off, enjoy!.... only other setting after that is luminance level, set at 50-60 for SDR, default level for HDR, don't adjust it. Also set Dynamic HDR Effect on. Pro calibration is the next step after those small adjustments.
SilaTeczy
Hello, I am the owner of the GZ950 and I have a question. First off, I have an Xbox One S, is it worth buying an Xbox Series X? Would the difference in graphics be large or similar? incl. RayTracing
The second is "HDMI 2.1" which just allow ALLM not 4K @ 120fps. So, in XSX games will works although 4k @ 60FPS?
Oh, I forget one thing. In TV menus is blocked option "Dynamic HDR effect" while playing games on Xbox One S.its default OFF and I cant change that Maybe Destiny 2 its not support HDR.
Regards.
Chamberlain
Well i havent seen a Series X but when i went from a Xbox One S to a PS4 pro/Xbox One X i already noticed quite a big difference and that is from the same generation. And the Series X/PS5 are more powerful than those as well so pretty sure the difference from a One S to a Series X is gonna be massive.
Lancia34
Regards.
Probably better asking about the quality in the XBox forums. 4K HDR games on my PS4 Pro look amazing so next gen will do as well.
AS for 4K @ 120fps, no chance with this TV but as you say 4K @ 60fps will be fine. The thing is to have AAA games running at 4K @120fps the graphics would have to be downgraded a lot (see Dirt 5 example) so 60fps is just fine and a lot of games I expect will only be 30fps with RT or under 4K, say 1440p @ 60fps.
I personally don't think there's much to worry about at all. If I was buying a TV today I would go for the LG CX just because it does support HDMI 2.1 but I'm not really going to be missing out much with my GZ :)
thx75
Good choice, our beloved Christopher Reeve during his night flying with Lois Lane in Superman (1978)... approved!! :)
sirbadger
This is my thinking, I'd like VRR but not fussed about my TV not supporting [email protected]
wesslan
Ubisoft confirmed we will se [email protected] with raytracing on PS5/XBX with Watch Dogs legion and I think this will happen more often with AAA games to keep the quality up. Some might get performance mode so you can chose which would be optimal. So no I wouldn't worry either about 120...
McSauce
Hi Guys,
Just bought tx-65hz1500e and I am very impressed with the quality compared to the old panasonic LED (had bad dirty screen effects). My only issue is that I would like to set the optimum sound settings. What requirements would you suggest?
luisreg81
I've bought a 65GZ950B and already own a X-Rite 1.
Would you recommend paying for the CalMan Home for Panasonic version or use the Ultimate licensed version from a friend?
Is there much of a difference between both versions? Going with the Home version means I can re-calibrate as much as I want in the future...
any thoughts are welcomed :)
Luis
devlino
Got my beam today, set up easily, question is..... Previously had a Bose system plugged into headphone socket, if missus went to bed early I changed sound from headphone to TV speaker in sound settings which made it quieter due to Bose sub and speakers disconnecting, if I change it now from home cinema to TV speaker it switched then immediately switches back...any help would be appreciated.
Lancia34
Think it will always swap back. Think there's a night mode on the Beam isn't there? I can check mine a bit later
Podcast: Best Hi-Fi products of 2020, Plus Best of the Month for TV Shows & Movies
Latest News
What's new on Sky and NOW TV UK for December 2020
  • By Andy Bassett
  • Published
PS5 vs. Xbox Series X: Which Next-Gen Console is Best?
  • By Rik Henderson
  • Published
Black Friday 2020: Best UK deals currently available
  • By Andy Bassett
  • Published
AVForums Podcast: 25th November 2020
  • By Phil Hinton
  • Published
