Panasonic GZ OLED Series Owners Thread
Mikeyt271
I was referring to the issue about the back cover not fitting. I will probably get a HDMI ARC compatible Soundbar in the future but for the timebeing I am sticking with my YAS-93 + Optical.
Sorry, I got you now 👍🏻
Is it better to go optical, better sound quality? Rather than arc?
steverobertsbbc
So seeing the player has 2 hdmi slots, it's video port to the TV and the audio port into the bar?
Why do you need to do that? Plug the player using a single HDMI cable into a spare HDMI port on the TV. Select that HDMI input. The sound will then be sent via ARC down to the soundbar.
I guess the only potential issue would be if that path into the TV and then out again to the soundbar didn't allow Dolby Atmos to be transferred. Try it and see.
tmg
I don't use ARC but I think is considered to be the better more modern way to do it as it can send other signals down the link too, so you can control your soundbar via CEC etc.
thedoswells
I would still do the 2 connections as it should allow uncompressed atmos if the player is connected directly to the soundbar. Atmos would be lossy if connecting to the tv and then to the soundbar via arc...
lgans316
Guys,
Please correct me if I am wrong.
The crackling issue is with the TV's internal speakers only and not when connected to any soundbar or even a bluetooth speaker?
tmg
Guys,
I've noticed it for the first time yesterday via soundbar on the Prime app. Not had any issues with Netflix.
Going to keep an eye on it going forward as I've had the TV more than a month now and it's the first time I noticed it.
lette
Thank you guys will try when I get home this evening
steverobertsbbc
Would you be able to tell the difference on a soundbar? I'm sure I wouldn't!
The convenience of having to only need to select one source rather than two would probably be more important for me. :p
mushroomkid
The crackling appears on a soundbar too?
That's worrying. I was keeping an eye on the GZ950 but may have to reconsider now. I can't live with spending so much money for something to have such a noticeable effect on my viewing experience.
It's a shame, I was looking forward to purchasing it
lgans316
I was very close to buying the GZ950 simply because it doesn't suffer from near-black-chrominance-overshoot issue that affects LG OLEDs despite it showing up only on few occasions with my ex-LG 65C8.
Looks like I will have to back LG again as this crackle on the Panny sounds quite fundamental.
thedoswells
Yes I completely agree with you. But for me, knowing that I could set it up like that would override the inconvenience. Either way, DV should work fine, as well as Atmos, so it should look and sound great :)
thedoswells
Just to clarify it does happen on some soundbars and not on others. I don’t get it on mine but the risk is there for any configuration I’m afraid.
knewt22
The crackling appears to have the potential to show up on a soundbar (or any surround sound speaker system) where the audio is being processed by the TV. So the built-in apps, or devices plugged into the TV and the audio going out over ARC. Where the devices are plugged into the soundbar, there shouldn't be any issue at all.
Glenn Keen
The best guess about the crackles is it's to do with processing audio formats, mostly surround ones. So if your TV is connected to a sound bar and using ARC or what ever Panasonic call their variant, you should still be able to get the crackles as the TV introduces it when it's processing the Audio before sending it to the soundbar.
Only time I've ever had it was on shows that were in theory 5.1 on Sky, and setting my Q box to Normal for audio totally fixed it.
Hopefully the firmware fix coming at the end of the month will fix it for good.
mikej
What effect would that workaround have on the sound for anyone with a 5.1 surround system. Do you end up with 2.1 ... or stereo sound instead of 5.1 ?
flyinggizmo
That's right. I've got my Sky Q connected by HDMI into a Sky Soundbox ( essentially a soundbar ) and there's no problem at all with the sound. However I use a Yamaha Soundbar connected by optical from the TV and get sound dropouts and crackling with the internal apps as in this case the sound is processed by the tv.
Interestingly, when the crackling starts if I turn Viera Link off the crackling immediately stops. The other way of stopping it is to turn the Sky Q box sound from DD to NORMAL and it doesn't happen. Really weird but at least I can stop it happening until hopefully this firmware fix arrives.
Glenn Keen
Off the top of my head I'm not sure what the Q box down mixes it to, but I would think it would be 2.1 Certainly not perfect, but it's a work around for me until the firmware arrives.
Plus I only use the speakers on my 950, so stereo isn't an issue. I have my 7.1.4 setup in my cinema room if I want "proper" sounds :)
jpr141
Cracking issue is a strange one. Just a 2019 thing? Did anyone have this issue or similar on the fz802?
Fillius
Panasonic TV's don't support DTS formats so by using ARC rather than a second HDMI from the BluRay you would loose out on DTS:X.
The conversion of the Atmos/TrueHD to Atmos/DD+ by the TV may also add latency and cause lip sync issues. Although hopefully not since it should just be able to pass the "core" component of the TrueHD without any decoding/re-encoding. It was an issue for Atmos/Dolby MAT from my Xbox, although this has no DD core.
Last but not least, using any DD+ source through this TV may introduce the dreaded crackling issue :eek:.
Having said all that, I had to disable CEC on my UB450 because my TV kept fighting for the right to handle the audio and kept switching the input on my AVR to ARC! Also, the UB450 has no audio-sync manual adjustment to correct any latency differences between the TV and the soundbar.
It's at least worth trying each way before settling though.
thedoswells
Watching a World Cup Qualifier in 4K & felt like a brighter picture. Surprised to see “Custom” appeal to my eyes in terms of grass colour & jerseys etc, but upon switching between it & “Pro 1”, I found “Custom” didn’t handle the darkness as well, losing detail of the trees in the background in the night sky.
So “Pro 1” wins again, for when THX Cinema‘s too dark.
Back to enjoying the Socceroos smash a minnow in 4K. 😏
I hope you guys aren’t going to start whooping us at footy too :confused:
But the 4K footy games I’ve watched recently look, and sound, really impressive. Still Pro1 or 2 for me...:)
Moonda
You’ve got nothing to worry about there.
We’ll just stick to beating you when it comes to the GZ Remote Control 😂 <—To keep things on topic. 😉
But yeah, I’m now converting to Professional 1 for all content bar films I think. THX Cinema for movie night only maybe...
Lancia34
It's a very difficult position really. I would probably wait a few weeks and see if the fix comes out and works. The TV is phenomenal and such great value as well and a lot of us don't have any sound issues at all (I did with a sound bar but not with my Denon amp).
Having one I could easily say just get it and hope it's a good one but as I said above maybe wait a few weeks if you can.
On the plus side everything else about this TV is stunning, perfect screen uniformity, amazing picture with pretty much everything put into it and decent price :)
tmg
Yeah the remote is really really bad. You would think that at this price point they would have made some effort to upgrade it and at least make the line of sight a bit broader or use bluetooth as the TV has that built int.
Lancia34
I'm lost with people complaining about a remote...since when was this a thing? ;)
I maybe touch the TV remote once or twice if I'm changing the picture settings or maybe a quick scroll through Netflix but it seems perfectly fine. Even if you use it for the built in TV etc... would it really get used that much?
Similar threads
Trending threads
Latest news
Disney+ subscribers experience launch day technical jitters
  • By Andy Bassett
  • Published
Netflix to stop supporting older Samsung TVs in December
  • By Andy Bassett
  • Published
Kanto launches TUK active wireless speaker in UK
  • By Andy Bassett
  • Published
Elipson launches new Planet W35 speaker
  • By Andy Bassett
  • Published
AVForums Podcast: 11th November 2019
  • By Phil Hinton
  • Published
Latest threads
