Panasonic gx7
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by STONESY, Apr 2, 2003.
  1. STONESY
    STONESY
    I have recently purchased a gx7 and having read the instruction booklet was of the opinion that the free angle flash could be operated whilst recording, however i can only get it to operate when taking stills.Is this correct or should the flash double up as a light if the conditions require it.
    Cheers,Stonesy.
  2. dts borg
    dts borg
    Sep 5, 2001
    577
    Hornchurch
    +8
    When I got my GX7 the guy in the store had the light on:confused:
    I can't get it to work as a light. Did you find out?
    ;) keith
  3. STONESY
    STONESY
    Keith,unfortunately not, yours is the only reply that i got, i think that i will contact the salesman at 'LETS GO DIGITAL' he was really helpful when i purchased my GX7 failing that i'll e-mail Panasonic UK,hopefully they should tell me.
    Is it me, or is the instruction booklet poor?
    cheers,Stonesy
  4. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    :hiya:
    I've had the GX7 since last summer.
    The flash is only for stills.
    You'll have to use the accessory shoe to attach a light,though it records in doors fine for me without a light.
  5. dts borg
    dts borg
    Sep 5, 2001
    577
    Hornchurch
    +8
    Really poor.....:thumbsdow
    Thanks Wayne:clap:
  6. STONESY
    STONESY
    Wayne, cheers for that, incidentally what do you think of the GX7.
    Stonesy.
  7. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    Brilliant,just the spec I was after,though I am dissapointed by the stills quality.I think I was expecting too much from a 1.2MP camcorder.It takes better close ups than landscapes,great ones actually.
