Panasonic GT50 (TX-P42GT50B) 42 Inch Full HD 3D Plasma TV Review
Discussion in 'Panasonic TVs Forum' started by The News Bot, May 14, 2012.
    1. The News Bot
      The News Bot
      News Supplying Robot
      Sep 15, 2004
      25,106
      Cyberspace
      +445
      Reviewed by Mark Hodgkinson, 14th May 2012. In its class the Panasonic TX-P42GT50 provides a peerless combination of outstanding black levels, flexible options and downright excellent picture quality, in both two and three dimensions.
      Read the full review...
    2. misar
      misar
      Sep 7, 2011
      76
      +13
      A rather trivial comment. I use the timer menu a lot on my older Panasonic to see what I have programmed for recording (you cannot do much while a recording is in progress). I find its location in the setup menu a bit inconvenient so for me the new arrangement would be a plus.
    3. evanfotis
      evanfotis
      Jan 28, 2010
      35
      11
      +5
      It was mentioned that
      Just to clarify, does this mean that when driven by a PC as a monitor for use with Photoshop for clients viewing critical imagery, it will not display full chroma 4:4:4?
    4. vism
      vism
      Feb 7, 2011
      3,010
      Royal Leamington Spa
      +1,188
      Has the increased brightness over the VT in pro mode come about because of a software update or has the GT always been that bright?
    5. NBrice
      NBrice
      Dec 6, 2004
      1,093
      +473
      Well I have this TV and I agree with everything in the review, except perhaps the input lag. It feels so much more responsive than my Samsung C750 (41ms) and also the 46" ES8000 I had, and yet it's allegedly slower according to this method. Perhaps it's down to the way plasma displays the images compared to LCD, but the GT50 feels extremely responsive to me and I normally have issues with displays with high lag.
      Also, the 50hz issue is most apparent in docushows with lots of fast shaky camera pans, like Come Dine With Me. White walls especially, seem to be noisy on pans and break up in to slight colours. Whilst an annoyance, so is the vertical banding and dirty screen effect I got on these pans on the ES8000 I replaced. The GT50 really does offer a phenomenal class-leading picture, most of the time. In fact, you can pay over £2k for the top-end LG LED model this year, and you still won't get this quality or depth of picture.
      Can't recommend this TV enough.
    6. Jon P
      Jon P
      Apr 8, 2009
      560
      46
      Watford
      +106
      now if only Panasonic could get rid of the flicker. It drives me nuts.
    7. vism
      vism
      Feb 7, 2011
      3,010
      +1,188
      Mark,
      I think we have both been following the thread that Vierrafan started about the 50Hz bug but I really don't think the subfields are the cause.
      You say that 50Hz has "less subfields". If true then 96Hz would have even less, making a p24 source even worse.
    8. hodg100
      hodg100
      Reviewer & News Writer
      Aug 8, 2005
      14,067
      3
      4
      +4,453
      I would have thought there's less subfield processing available, certainly than @60Hz, as 50Hz is 'double scanned' to 100. Panasonic keep a lot of this sort of stuff shrouded in mystery but it seems logical to me that 60Hz is better catered for with 600Hz sub-field processing. It's a bit of speculation, but from the 60Hz video I've seen with the Panasonic's it's handled better:)
      EDIT: Perhaps rather than saying 'less subfield processing available', less optimal...would be better?
    9. vism
      vism
      Feb 7, 2011
      3,010
      +1,188
      Yeah, but that's my point.
      Because it's double scanned, you're splitting the subfields between 2 refresh cycles.
      With p24, you're splitting between 4 refresh cycles so there are less per cycle.
      I don't know how or what but I'm sure there's more going on
    10. hodg100
      hodg100
      Aug 8, 2005
      14,067
      3
      4
      +4,453
      Fair enough, just my opinion on that one, I'm a minimalist kind of guy:)
      Provided the video card can output a YCbCr signal, it should work.
      Difficult to answer but I suspect it would have been like this anyhow.
      Interesting, I found it actually fine for my needs but noticeably a bit more sluggish than my 2010 Panasonic here. I don't think it's a particularly high lag, just a bit more than expected. There's very little opportunity for the device to get it wrong, it's very simple really. Who cares if you're happy anyhow:)
    11. hodg100
      hodg100
      Aug 8, 2005
      14,067
      3
      4
      +4,453
      Definitely agree there. Let's see if we can get Panasonic to shed a bit more light on it:)
    12. Tolq
      Tolq
      Aug 8, 2008
      1,395
      63
      +166
      Could this be down to the different filters, I wonder?
      I've seen both the GT50 and VT50 in the flesh now, and I like both of them - although I can't really justify spending 4-500 quid more on the VT, especially not when some retailers are throwing in free 3D glasses with the GT50 as well.
    13. vism
      vism
      Feb 7, 2011
      3,010
      +1,188
      Ah, now you see why they're phasing out the GT.
    14. vism
      vism
      Feb 7, 2011
      3,010
      +1,188
      Deffo, perhaps you guys could ask a Panasonic tech guy to fill us in with an article.
    15. Tolq
      Tolq
      Aug 8, 2008
      1,395
      63
      +166
      Indeed - might have to get one sooner rather than later. Seeing the new sets has given me the itch as well :D
    16. hodg100
      hodg100
      Aug 8, 2005
      14,067
      3
      4
      +4,453
      Answered in VT50 thread with:
    17. deblee
      deblee
      Dec 16, 2010
      2,015
      63
      +140
      Great review again:smashin:
      I will mention again about Normal mode, it defaults to CATS on so will be dull the majority of time (except when the sun is shining)
      Would be interested to know what energy comsumption this mode uses when CATS is not used?
      Incidentally CATS works very well in a sun drenched room but the gamma is skewed:rolleyes:
    18. jlmcr87
      jlmcr87
      Mark I have the GT50 and I´ve noticed black levels are less black in cinema and professional modes than in normal mode, why? also i have noticed a red grainy tint (with a black screen) unless you put brightness to -1 in normal mode. Can you check this? Thanks
    19. hodg100
      hodg100
      Aug 8, 2005
      14,067
      3
      4
      +4,453
      All modes I really looked at (THX/Pro/Cinema) in the sample had identical black levels. Does Normal crush a bit of low detail or do you mean a blank screen is darker in Normal?
      The grain is PWM noise, getting Brightness set to a certain level gets rid of it. As you have found.
    20. jlmcr87
      jlmcr87
      I mean black levels in general are better in normal mode.
      A completely black screen or the black bars of a film are blacker in normal mode. In cinema, thx or professional with a completely dark room I apreciate the blacks more greysh.
      My model is GT50Y
    21. hodg100
      hodg100
      Aug 8, 2005
      14,067
      3
      4
      +4,453
      There's been a bug reported with the European sets where it's exactly as you describe. Sorry, the UK versions we've tested haven't shown it, I think the best bet is to report it to your local Panasonic customer services.
    22. HMHB
      HMHB
      Nov 11, 2001
      27,233
      Nottinghamshire
      +6,142
      Thanks for yet another great review Mark :thumbsup:
      Have Panasonic made any improvements since I got my plasma a few years ago for watching standard definition material? I imagine that nobody bothers about it any more though :(
    23. hodg100
      hodg100
      Aug 8, 2005
      14,067
      3
      4
      +4,453
      Hi John
      Yes, SD scaling is much improved over the G10 but bitrates get ever lower so it's a bit like manufacturers are chasing their tails. Don't expect them to make Forest look good on BBC late of a Saturday evening though!
    24. HMHB
      HMHB
      Nov 11, 2001
      27,233
      Nottinghamshire
      +6,142
      Cheers Mark. I don't watch the footie on Saturday night if we lose, so I've not watched it much over the last year :laugh:
    25. catw4x
      catw4x
      May 31, 2012
      3
      Hi mark. I have just got a vt50 50inch and its a bit too big for our setup. Am thinking of exchanging for 42 gt50. I also find the vt50 picture for normal tv watching to be way too dull. A white screen is not full bright white but more a dull greenish tint. Is gt50 brightness a noticeable jump up? When I say brightness I mean light output. I have a 5 year old Samsung plasma and the white is perfect on that.
    26. Turrican4D
      Turrican4D
      May 4, 2010
      100
      +20
      Too big??? :confused:
      There is no "too big" when it comes to high definition! :lesson:
    27. HMHB
      HMHB
      Nov 11, 2001
      27,233
      Nottinghamshire
      +6,142
      There is if you have to sit too close and are watching a lot of SD material - which the majority of people still have to suffer in this country :(
    28. holden1
      holden1
      Mar 2, 2010
      Can anyone help me estimate the cost of power consumption for the TX-P42GT50B please?
      On Panasonic's tech spec it says:
      On mode Average Power Consumption: 137 W
      Annual Energy Consumption: 200 kWh
      Standby and off-mode power consumption: 0.30W/ 0.25W
      what would this (200kWh/yr) approximate cost to run for a year?
      My provider is E-On
      I'm looking at buying one from John Lewis (if they ever get any stock) :)
    29. holden1
      holden1
      Mar 2, 2010
      in answer to my own question, with E-On I am paying:
      First 900kWh each year: 22.98p each
      Next kWh 12.5p each
      so assuming I was already into the cheaper band for the year (12.5p), this would work out at £25/yr (have I got that right?)
    30. HMHB
      HMHB
      Nov 11, 2001
      27,233
      Nottinghamshire
      +6,142
      How much a telly costs to run a year largely depends on how many hours a day you watch it for! :D
