DoubleDeuce1973
- Joined
- Apr 4, 2010
- Messages
- 11
- Reaction score
- 2
- Points
- 1
Pixmania have the 42" for £883 and the 46" for £983 plus discount codes available to take another £25 off. They don't have the 46" in stock until 9th April.
This is not a fault. This happens with SD broadcasts, the top/bottom pixels contain "data" for teletext etc. Your old CRT would overscan automatically. Now you have the option. You wont see it on HD broadcasts.TV is all but 24 hours old and already I'm impressed... SD is almost HD!
I seem to have a similar white line thing going on as 'rchads89' and 'deckardian' in 16:9 (part 1 thread). It only happens on the AV1 input/SCART (dont laugh!) starting on the top left and is like the line in the middle of the road, extending to 1/2 of the screen. AV2 is fine... and I'm not happy enabling 16:9 Overscan...
Any other suggestions? Is this usual behaviour? I may put a call into Panny.
It's Nvidia....there has to be a setting somewhere but I can't find it. it's annoying not beeing able to see the entire desktop.Try adjusting the overscan settings on your computer (e.g. if it's ATI).
If it helps mine is noticeable from 3 meters away... which is a lot noisier than the CRT it replaced...
I used to own an older Plasma that buzzed a lot louder but after inspection by a local "Panasonic" certified engineer it was found to be "in spec". The TV I replaced it with buzzed a whole lot less. Seems to be the luck of the draw
Im thinking of setting up a freesat dish for freesat HD as my aerial for freeview is rubbish!!! It gets the channels but its not really that good its like 20 year old!
So my question is if i buy a dish and the cable does the G20 already have a good high end reciever inbuilt?
Anyone???
It has a satellite receiver that is capable of receiving HD broadcasts. Not sure what you mean by 'high end' though?
I mean if i buy a dish and put it on and run the cable into the tv is that all i need to recieve freesat HD?
yes(though obviously you will need to align it and buy a LNB too,unless i comes with the dish)
Intelligent Frame Creation: Has any tried the G20 with IFC on and off? How effective is it at reducing judder? IFC on the S10 seems to make barely any difference.
IFC:Intelligent Frame Creation: Has any tried the G20 with IFC on and off? How effective is it at reducing judder? IFC on the S10 seems to make barely any difference.
In regards to THX I keep it on all the time although i find that it is at its best on an evening, i watched both toy story 1&2 the other evening and i was gobsmacked at how good the picture was i just couldnt stop grinning. however when watching the same during daylight i found the picture whilst good, it wasnt bright enough and looked a llittle washed out, notch the brightness up a little tho and looks great again! so overall im very happy with this mode, plus its great for gaming
regards
Musicville
The box dimensions are 134cm x 29cm x 86cm (LWH).
