Panasonic FZ30 - Noisy!!
Discussion in 'Photography Forums' started by witters, Aug 19, 2005.
  1. witters
    witters
    Jul 13, 2000
    12,657
    Yorkshire
    +293
    Take a look HERE for a full review. Looks good other than high noise issues above ISO 100.
  2. Pete Delaney
    Pete Delaney
    Mar 14, 2005
    3,212
    Lincolnshire
    +653
    And I thought Panny were on to a winner :(
  3. Radiohead
    Radiohead
    Dec 24, 2001
    4,396
    Amazingstoke
    +432
    Noise above even ISO100 - that's poor.
  4. RobertP
    RobertP
    Nov 21, 2002
    529
    19
    Woodford Essex
    I liked the bit about more optical zoom by choosing a smaller area of the sensor to be used. So much different to 'digital zoom' :)... not.
  5. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    Bit like my 300D then.... :eek:
  6. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    "The noise levels aren't too much worse at ISO 100, but once you go any higher things go downhill rapidly. Detail is lost at ISO 200 and noise levels are very high at ISO 400. Enough detail is gone at that setting that even with noise reduction software you won't be able to get much of a print out of the photo."
    £550 :laugh:
  7. mjw123
    mjw123
    Apr 21, 2004
    1,302
    48
    +32
    Have to admit folks it does make dissapointing reading........
    Would seem the FZ20 is still best in class.
    (His Summary)
    What I liked:
    Very solid SLR-style body
    12X optical zoom lens (though a little slower than on the FZ20)
    Optical image stabilization
    Robust performance, especially with a high speed SD card; new focus modes are awesome
    Full manual controls plus the ability to fine-tune white balance
    Handy zoom and focus rings around lens
    AF-assist lamp; good low light focusing
    Flip-down, rotating 2-inch LCD display
    LCD/EVF usable in low light, at last
    Redeye not a problem
    Support for RAW and TIFF format (though see issues below)
    Supports filters and conversion lenses
    Hot shoe for external flash (though no TTL support)
    Great continuous shooting mode
    Very good movie mode; VGA, 30 fps resolution, zoom can be used during filming
    Live histogram in record mode
    What I didn't care for:
    Images are too noisy, especially at high ISOs (see workarounds earlier)
    No RAW image manipulation software included
    No focus distance shown in manual focus mode
    No USB 2.0 High Speed support
    Would've preferred an LCD that flips to the side
  8. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    You have to wonder what their R&D department were thinking
  9. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    haha yup, posh way of putting it really, even if the lens (when enabled) only projects onto the centre portion of the sensor its still gonna loose quality, and well yup, thats digital zoom!
  10. MattB1
    MattB1
    Yep - my C765 has the same amazing feature. 10 X zoom at 4mp or an amazing 12 X zoom at 2mp. Needless to say that amazing option is switched off.
    It's dissapointing to see that they haven't sorted the noise issues out on the FZ30.
    I would always avoid any camera unless it stated very good image quality in the "likes" section and sadly that appears to be missing on the FZ30 review.
  11. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
