Panasonic FZ series (802 & 952) OLED Owners Thread
MultiRoom
No one turned up evidence that they were arbitrarily nobbling peoples devices for any other reason.
Maybe because IOS isn't open source, so no one can prove anything about the way the OS was throttled, and certainly no one can prove the reason why - but of course it's all a bit suspicious when Apple denied it, then ended up admitting it when the pressure mounted. Your anecdotal evidence counts for nothing unfortunately.
For a software engineer you're not making a whole lot of sense.
By the way, I'm a former programmer, I then transitioned into IT consultancy and run my own business, and now have career experience in excess of 25 years, so your 10 years of embedded design and software engineering are relatively unimpressive to me. It certainly doesn't make me think you're more qualified than I am, with what are simply your points of view. That's all they are.
I have a point of view, you have one too. Let's leave it at that.
steverobertsbbc
Has there been a firmware update recently, as I can't understand why this stuttering has just started? First 3 seasons of Suits did not see a single stutter, now in season 4 it happens every couple of minutes!
Had you previously been watching the HD versions and now you're watching the 4K HDR versions of the new season?
Unlike Netflix, you have to choose which version you want to watch on Prime. Normally you really have to go looking for the 4K version way down the list, but new seasons tend to get placed in one of the top rows and actually the 4K version might be the first you come to.
Not sure if Suits is available in 4K, but if that's what you've been watching, try looking for the HD version instead and seeing if that's better.
5to1
Perhaps have another read. I mentioned people from the Jailbreaking/reverse engineering community also took an interest in this issue. As did many other professionals.
There's plenty of information and analysis out there. Users started suffering random shut downs. Nobody knows when Apple identified the issue was due to battery degradation resulting in erratic power deliver under peak load. But people did dissect the update which deployed throttling to address this. Apple did not admit to this until then. The general consensus is that they deployed the throttling to stop random shutdowns.
Most professionals (Embedded Design, Software Engineers) concurred this was the logical approach. As a software engineer I trust you agree ungraceful system shutdowns are not desirable (but perhaps not since you're the first software engineer i've encountered who argues against software updates). The bone of contention was that they were not upfront about what they were doing.
In fact they still do exactly the same thing. However, since iOS 13 they make it transparent and inform the user the battery has degraded and it is advisable to change it.
As I said there is plenty of analysis on this. Anyone interested can easily take a look and determine who isn't making much sense.
The only thing we can agree on, is that we'll have to agree to disagree on this and the merit of post deployment software updates.
5to1
Is this a little off topic?!? 😃👍
Well the underlying argument is wether TV manufacturers should be deploying software updates, particularly for security and device protection (DOG dimming).
I'm certainly not the only one displeased with the apathy of some manufacturers. And I certainly don't think the argument updates "screw things up" is valid.
But I'll leave it there, as the point has been made. And as I said there is plenty of info out there WRT the Apple update, which was cited as an example of bad intentioned/regressive updates.
steve sph
I have had the 55fz802 since June and until now have had no issues. The picture quality is absolutely amazing.
However, this week, whilst watching Suits on the TV's Amazon Prime app, I am getting lots of stutter. Happening numerous times through each episode. Thought it was a bad broadband connection at first, but has been doing it for the last week now!
It's not motion judder, which has been mentioned before on this forum. It's definitely a stutter. A previous poster described it well as 'A sudden discontinuity in motion, generally perceived as either a skipped or a repeated frame due to a breakdown in the motion processing in the TV'.
If I can't find a solution, TV will have to go back as it's unbearable!
BTW, I have all motion processing turned off (IFC black frame etc.)
The only time I've experienced anything similar to yourself was when I watched Bosch series five about a fortnight ago in HDR - nothing major, but every 10 minutes or so the odd judder would appear but that was it, and you were left wondering if it had actually happened at all.
But it bothered me enough to don my anorak and get a bit anal, (no, this isn't a veiled reference to dogging before anyone messages in disgust and/or excitement), so I watched the same episode via the Prime app on my Panasonic UB820 and lo and behold it did precisely the same.
So clearly this suggests the fault doesn't lie with the 802's inbuilt Prime app but rather with the TV itself.
My download speed is 100 and something so that's not a factor either.
It's weird, because on all the other Prime and Netflix HDR output shows no signs of judder.
Or if it does I'm too blind to notice and a trip to Specsavers may be overdue.
And in over 12 months of happy watching that is my one and only quibble.
In the grand scheme of things I reckon I can live with that.
MultiRoom
Pretty much my exact experience. Occasional, doesn't happen on all HDR content and doesn't matter if its the same material displayed via the inbuilt apps or external devices, proving the issues is the TV and not the source. Given it's so occasional I'm prepared to overlook it.
I'd happily accept a FW update to address it though, as long as it doesn't cause any knock on issues. Much like those that Apple send out. :rotfl:
scr222
My 55FZ802B has a brilliant picture on HDTV but a dire picture on Analogue (Front door camera in a block of flats) The picture looks much better on other tv's so it is not the signal quality. Any ideas?
steve sph
:D
Worms/of/can - Hell hath no fury like an Apple fanboy scorned, my friend.
I foolishly dared to suggest their products were overpriced and and style over substance on another forum.
The death threats still arrive, although not quite so frequently.
5to1
:D
Not an Apple fanboy mate.
Only posting to clarify that. Won't be opening the can of worms.
Daveykinetic
Tried various combinations trying to eliminate the green colour shift problem im getting. Tried multi room sky box. Recordings of football on both boxes. Live football and golf. Changed hdmi ports. Also tried BBC I player built in app for a recording of motd. I still get the green colour shift no matter what. I also got it in my ez952. I sit off centre to the screen. So the rhs of screen is always a lighter green. Then if I get up and walk from right to left the colour shift is very easy to see. Does no one else see this? I can't be the only one surely lol. I bought oled for the great viewing angles but in this instance it's terrible
5to1
Thats definitely one area we have no complaints. Consistency across pretty wide viewing angles (we have a large sofa opposite the TV) has been one of the big bonuses for us. No discernible colour shift at all, even if sitting at either edge of the sofa, or moving from one side of the room to the other.
Daveykinetic
Do you think I may have a faulty model? It done the same on my ez952 so I find it very strange. It can't be the sky boxes as it does the same thing via BBC I player built in app
sonnyRVN
Do you have any examples of the fault?
As mentioned prior viewing angles are pretty much perfect on any OLED in fairness, I watch loads of sport on mine and never seen an issue.
Daveykinetic
Yes please see attachent. Look at the right hand side of screen. This is from where i sit. You can see the green is completely washed out on this side of the screen
sonnyRVN
Now view from the left hand side of screen. You can see the green washed out colour has now shifted
I have to say that doesnt look healthy or normal at all. How is it to you when you sit dead straight in front? Im Watching BT sport ultimate right now (via TiVo V6) and no colour Shifting issues. Have you tried some test slides? Could possibly be a signal issue?
Daveykinetic
Just checked sitting straight on. I thought it was ok straight on before but I've now noticed it's still not. As you'd imagine I'm finding this issue very frustrating. What can I do to test things further?
sonnyRVN
These pics are from the built in bbc i player app so it must be a problem with tv and not the sky q box
Is it solely when watching football?
or specific to green colours? Do you see it when watching other content like
Movies E4, amazon prime / netflix etc.
Have you tried a full factory reset?
Daveykinetic
Ive not noticed it in any other content other than football. But 90% of the time im watching football so this is a big issue for me. How do i factory reset the tv? Ill try that
sonnyRVN
Menu > setup > system menu > shipping condition.
I believe it that of the top of my head. Have you played around with any advanced picture settings etc?
Hopefully full reset makes an improvement.
Daveykinetic
Edit: factory reset the tv and it's
Just tried the factory reset. It's no different unfortunately. Yes I've messed around with different picture settings too. Some picture settings it's harder to see but it's still there. Once I know it's there it can't be unseen. I've just messaged Panasonic. Maybe they could replace panel? I've already had my ez952 replaced due to the panel maintenance rectangle. After one replacement set already, where do I stand?
sonnyRVN
It’s shame full reset didnt help, out
Of Curiosity what picture modes where you
Using? General Consensus seems to be Pro 1/2 & thx cinema to be the best.
Log an incident with Panasonic or even whomever you got the tv from, if they find a fault they may well exchange the panel, I’ve never needed a panel Replacement only ever had 1 tv get fully replaced and that was years back.
Daveykinetic
Currently I'm using thx bright room. I've had long stints using pro 1 pro 2 and thx cinema. I find all the latter are either too dull or crush blacks so Ive settled on thx bright room for the moment
steverobertsbbc
@Daveykinetic, I've just had a look at this on my EZ and I can confirm that there is a colour shift on green which changes with viewing angle. Essentially, if you move around the TV, green looks more yellow on the side that you're on. It's pretty flat directly on axis. I tried looking at a green test pattern (there's one on youtube called "4K 24fps Full Green Test Pattern") and can discern the colour shift on this. I suspect that this shift becomes more apparent when the camera pans and parts of the picture change colour as they move from one side of the screen to another, so it's much easier to see it on a football match than on a solid green test signal.
Clearly, this is not anything that you can change by resetting anything in your TV. It's a physical effect related to viewing angle, not to any settings in the TV. It's probably to do with the anti-reflective filters built into the front "glass". As such, I just don't think that there's anything you can do about it, I'm afraid. Sod's Law dictates that it's probably worse on green than any other colour, so football is going to show it up the worst.
Daveykinetic
Gladly I'm not the only one with this problem. I had the same problem on my ez952 but I put it down to no absolute black filter. I can't understand how some of us are getting this and others not? I bought oled specifically for wide viewing angles. Turns out it's the worse than numerous lcds I've had in the past lol. Now I know it's there I'm never going to be happy with this tv if nothing can be done about it
sonnyRVN
Im watching the Leicester/Arsenal game right now and tried pausing and viewing from straight on to wide and can see no distortion or colour shift fluctuations (other than the standard changes due to shadows of players and the use of Floodlights along with the pouring rain lol).
Similar threads
Trending threads
Latest news
McIntosh releases DA2 Digital Audio Module Upgrade Kit
  • By Andy Bassett
  • Published
Sky TV offers cheaper Sky Q box with updated features
  • By Andy Bassett
  • Published
Fyne Audio unveils its first home install loudspeaker line up
  • By Andy Bassett
  • Published
Best TVs of 2019 - Editor's Choice Awards
  • By Phil Hinton
  • Published
AVForums Podcast: 18th November 2019
  • By Phil Hinton
  • Published
