Panasonic Freeview box TU-CT20 problem
Discussion in 'Freeview & YouView' started by talacrush, Dec 27, 2004.
  1. talacrush
    talacrush
    This may be a strength of signal prob .. I'm not sure. Anyway, its quite noticeable that when watching digital Freeview channels, voices lose sync with lip movements etc and its really distracting (we had a new digital aerial fitted btw so that shouldn't be the problem). Any quick solutions?
    Are other digital boxes better? ... I gather the TU-CT20 is an old model. Ideally I want one that has Smartlink so that I can wire it up with our new Sony dvd recorder (RDR-HX900) and use its features. 7day EPG would be good too.
    At the moment I just can't get the recorder to pick up the Freeview channels anyway but the TV picks them up fine (apart from the sync prob just mentioned above).
    tia
  2. talacrush
    talacrush
    Any takers on this?
