Panasonic Fan Do I Change ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by lurcher, Dec 7, 2004.
  1. lurcher
    lurcher
    May 15, 2003
    4,113
    Stalybridge
    +202
    Had Panasonic dvd recorders dmr E 20 and currently have E 60. My needs include dv input and I am considering upgrading to a hd model.
    The E 95 appears to have the features I require but is a little out of my current budget.
    Never considered other makes but after scouring this forum the Toshiba XS 32 seems appealing for the price ( considerably less than the similar specced panny 95.
    Will I be as satisfied with a Toshiba as I generally have been with Panasonic machines or is it a whole new learning curve ?
    TIA
