Panasonic EX75 Remote codes for an LG?
eddie_fb
Hi All,
I have just purchased an EX75 from Currys, in order to simplify my system (get rid of set top box, much fewer wires etc...)
To this end, I would like to use the Panasonic remote to control the LG RZ-37LZ55 LCD TV I own. I have tried the GOLDSTAR/LG code (31) but nothing happens. Does anyone know of any other codes to try?
I assume I am inputting the codes correctly, pressing and holding the tv on/off button, whilst typing 31 in?
Cheers for any help.
Eddie.
ROYOLD
Think its a bit of hit and miss with these codes. They use several. I have a Medion 8 in 1 learning remote and also a 28" LG CRT TV. The codes listed for the LG TV's are 003 009 012 019 051 084 088 093 119 129 131 149 169 171 None of these worked so I set up in learning mode. The actual code which works my LG TV is 042. So much for the codelist!
Fred Smith
Your LG TV was probably made by Beko hence code 042.
Regarding the OP. LG LCD / Plasma TV's use differant codes to their own manufactured CRT TV's so finding a code might be difficult.
