Panasonic EX75 high speed DVD to HDD copying?
Discussion in 'Blu-ray & DVD Players & Recorders' started by np1664, Sep 17, 2007.
  1. np1664
    np1664
    Aug 2, 2006
    42
    Is this possible?
    I want to make back up copies of some of our home DVDs onto the HDD but only get the Normal speed options.
    Settings:
    Others-Setup-Disc-Settings for recording = high speed copying turned "on"
    Others-Advance copy
    -Copy direction = DVD-HDD
    -Copy mode = Only normal speed are options. High Speed is greyed out.
    Manual sort of says you can copy DVD to HDD in high speed mode but is not clear.
    thanks in advance for any help.
    np1664
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,158
    +7,098
    With the EX75 [and previous generations] it is necessary to have MADE the recording you wish to copy, with the RFHSC setting [ Record for High Speed Copy] ON PRIOR to the recording.
    It cannot be done retrospectively... and evidently the recordings you are trying to copy were not made with that setting ON... so unfortunately you have no choice but to copy in real time.
  3. maldonian
    maldonian
    Nov 25, 2004
    919
    43
    +91
    Apart from DVD-RAM, you can't high speed copy from DVD to HDD - you can only high speed copy from HDD to DVD (and only recordings made with the high speed copy option on).
  4. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,158
    +7,098
    Yes of course - Silly me.
