N
NigeD
Could someone tell me if the problem is one of connectivity, or one of incompatible components?
Cheers!
NigeD said:Thanks Ian, I will give it a try later!
ROYOLD said:For Ian C.
I have the Panasonic E85 dvd recorder with its AV1 outlet connected to AV1 on the TV via a scart switching box which accepts three inputs. The Sagem freeview STB is scart connected to AV2 on the E85 and its vcr scart is connected to AV3 on TV.
The Digifusion FVRT 150 twin tuner PVR is connected by scart to AV3 on E85 which is 3xRCA Composite. (note I could use this Av3 connection for another STB in place of the Digifusion PVR). Therefore I could record from either STB to the dvd recorder by selecting AV2 or Av3 on the recorder as the input source. Sounds complicated but I hope you can fathom it out.
