Panasonic ES10 DVD RAM question
Discussion in 'Blu-ray & DVD Players & Recorders' started by jtorry, Aug 10, 2005.
  1. jtorry
    jtorry
    Nov 8, 2001
    520
    I am about to order an ES10 from ebuyer and need to get some media. Do I need the RAM discs in the caddy or will the disc on its own work? Does the recorder come with any media in the box?
    Can you only do editing on DVD RAM discs?
    Thanks.
  2. Goooner
    Goooner
    Jul 23, 2005
    31,712
    2
    Milton Keynes
    +10,664
    The disc on it's own will work.
    Mine came with 5 RAM and 5 DVD-R, not sure if this is standard though.
    I think you can only edit with RAM, not 100% sure though, I've never tried it.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,241
    Warwick
    +2,282
    The machine will use either. If you intend to use the DVD-RAM in other equipment then I would suggest getting caddyless discs.
    Yes. Use DVD-RAM for editing, DVD-RW or DVD-R for compatibility.
