Panasonic EH60 recording titles
grd2
Joined
Oct 14, 2005
Messages
216
Reaction score
2
Points
Location
Bookham Surrey UK
Does the Panasonic EH60 record titles of TV recordings automatically like my Panasonic HD685 VC recorder which gets the info from teletext which you can then pull up from a menu to look for a specific recording?
Yes is does. For analogue recordings it does it the same way as the VCRs; for Freeview digital recordings it grabs the title straight from the EPG as you program the timer; if you program the old way, it gets the title from the EPG (I assume) during the recording. There is also the option (that I never bother using) to set the title yourself to something completely different (by a tortuous manual typing-in process) whilst you're programming the timer, but I can't see much of a use for that.
I use the typing in method on my E85 for repeat recordings, for example I record Fry & Laurie every day of the week so each one is identifiable :)
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
