Panasonic EH50 HDD Upgrade
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dickster, Sep 13, 2005.
  1. Dickster
    Dickster
    Oct 19, 2004
    105
    +4
    I know this was discussed a couple of months back, but I was wondering if anyone had ever reached a conclusion as to whether the HDD in the EH50 can be upgraded or changed for a faster disc ? :thumbsup:
    Dickster.
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    No one has successfully upgraded any panasonic dvd recorder to a larger disc, without access to manufacturers upgrade software, ie it is sometimes availble in japan, at significantcost, for local machines, done in the factory.
    There is no point in putting in a faster drive as it will not improve the performance speed, indeed if it draws extra power it is quite likely that the unit will play up during dvd burning as the power supply will be designed to be adequate only for the original spec.
