Panasonic E95 disappointing
Discussion in 'Blu-ray & DVD Players & Recorders' started by BillJohnson, Aug 22, 2004.
  1. BillJohnson
    BillJohnson
    Aug 4, 2004
    134
    Warrington
    +8
    Having bought the Panny E95 I was disappointed to find that you can't record mpeg4 to the PC card like you could with the E100.
    When I tried the progressive scan output to my Philips plasma I found that the Philips doesn't accept progressive scan (confirmed by Philips) unless it is from the VGA input. It would be interesting to know if this is common with other makes.
    Unlike the Pioneer Panasonic doesn't support Secam so you can't record French TV from satellite.
    The manual refers to the AV1 socket as an input/output but as far as I can see only the AV2 will input. I had intended to use the component output to the plasma and use AV1 as an extra input.
    Strangely it seems to have one feature that everyone says is lacking - it will dub from DVD-R to the hard disk, provided it's not copy protected of course.
    There is no way of recording from any programme guide, either web-based or teletext-based.
    Apart from the above it is easy to use and produces good recordings.
    Bill Johnson
  2. get1a2get1a2
    get1a2get1a2
    out in december
    Panasonic DMRE500
    Plays pre-recorded DVD's & CD's
    Built in analogue TV tuner
    Ethernet connection for networking
    DVD-Audio (5.1) playback
    Built-in Dolby Digital and DTS Decoders
    MP3 Playback
    Records on DVD-RAM & DVD-R Video Blank Media
    Will make discs that will play in most existing DVD players (DVD-R only)
    Uses VBR (Variable Bit Rate) Technology to maintain high picture quality
    Videoplus+
    Playback programs recorded to DVD-RAM or HDD while watching another program on DVD-RAM or HDD
    Internal 250GB HD for time shifting
    High speed transfer to and from HDD to DVD-RAM
    When transferring at 1x speed from HDD to DVD-RAM or DVD-R, formats can be re-encoded eg XP mode > EP mode)
    Allows non-linear editing to transfer to DVD-RAM and from DVD-RAM to HDD
    Playback while recording even at high bit rates (HDD and DVD-RAM)
    Uses the single layer 4.7GB DVD-R (once only) system and DVD-RAM 4.7Gb systems
    Records in real-time using MPEGII compression-Up to 8 hours per disc
    Quick recording function automatically finds the blank part of the disc
    Variable Data rate and variable resolution settings
    Disc navigation thumbnail chapter view
    Built-in time base corrector that delivers highly stable, natural images
    Front A/V input
    Full RGB in and out
    Flexible recording mode allows you to manually a time for recording and the player will set the best possible bit rate for that time, say 1 hour 15 minutes to fill a disc
    Can record and playback NTSC and PAL
    Progressive Scan (PAL & NTSC)
    Firewire (i-link) DV input
    PCMCIA PC Card upgrade slot
    SD Card Reader for JPEG, TIFF and MPEG4 playback
  3. dakara
    dakara
    Bill,
    FRENCH TV-all of the French channels from Astra 1 at 19.2 are in PAL numerique,
    those from Atlantic Bird 3 at 5.0 West are in Secam Analogique. You should have no problems recording from Astra
    Salutations
  4. LaTiNo
    LaTiNo
    Aug 19, 2004
    39
    Any idea where the ethernet connection will be used for exactly?
