Hi all, Does anyone know if it is possible to use the TV controlls on a Panasonic e85 remote control to turn on a Bang and olufsen TV? In the panny manual there are codes to set the remote for many TV manufacturers but not, it seems, for B&O. Any ideas? Thanks
Did you ever get anywhere with this as I have the same problem with a B&O tv and a Toshiba RD32XS recorder - there is a code in the manual for B&O, but it doesn't work. Thanks
Well, I would say that you will have hard to get this kind of solution. But, what can be done is to install a hardware remote converter so that you instead can use the B&O remote to controll the DVD-unit.... ok, you will miss out lots of the features, but you should be able to play and record. Check this site: http://www.stonedesign.dk/en/
