Panasonic E85 Record Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by asimmd, Aug 11, 2004.
  1. asimmd
    asimmd
    May 6, 2004
    518
    +11
    Hi All
    Apologies if this has been asked previously. My hard drive is currently empty, when I press the record button, the unit will begin recording,but if there is a delay to the prog starting,say, they run another trailer before starting the movie,how do I get rid of the stuff before the movie starts,before saving to disc?
    Also,When I want to save a film to disc from the hard disc,how do I set a start and end point so I only save the film to disc and not a load of adverts,or other undesirable stuff?
    Many Thanks
    Alan
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,868
    Warwick
    +2,784
    You can use the "Partial Erase" function to actually delete parts of your recording you do not want. Or use the "Playlist" function to specify these edits without deleting anything. :rtfm: and then if you need further detail we will be happy to help ;)
  3. asimmd
    asimmd
    May 6, 2004
    518
    +11
    Hi Rasczac
    I have :rtfm: and all I succeeded in doing was erasing the film I had recorded.The manual is not laid out in a logical way,an idiots guide would be appreciated by this idiot.
    Thanks for your Patience,you'll need it
    Alan
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,868
    Warwick
    +2,784
    How on earth did you manage that? Using Partial Erase is easy. Follow these steps:
    1) Go into DIRECT NAVIGATOR
    2) Select the programme you have recorded by using the direction keys on your remote
    3) Press SUB MENU to get the list of options up
    4) Scroll down to PARTIAL ERASE
    5) In the Partial Erase screen use the normal keys (Play, Pause, Fast Forward, Rewind etc) to navigate to where you want to cut and then press ENTER.
    6) Repeat for end point of the cut.
    7) Now use the arrow keys to select NEXT.
    8) It will ask you if your sure, click YES
    9) When you done editting select EXIT
    Manual page 30/31 refers!
  5. asimmd
    asimmd
    May 6, 2004
    518
    +11
    Hi Rasczak
    Many thanks for that,I have no idea how anyone can understand the Manuals,I can't even programme the Video,so I had no chance with this.
    I will try A.S.A.P but look out for more stupid questions.
    Alan
    :suicide:
  6. Rob20
    Rob20
    Jul 3, 2004
    3,188
    +722
    I think I found it easy as I was used to editing mini discs in the same way. All you're doing is cutting out chunks of info you don't want. You just have to tell the player the start and end points of this chunk of info so it can delete it. Not really thast difficult once you've done it a few times. Though I admit i did accidently delelete the wrong part of a recording once. :rolleyes:
