Panasonic E85 Chanel 4 set up
Discussion in 'Blu-ray & DVD Players & Recorders' started by Churchclose, Aug 29, 2004.
  1. Churchclose
    Churchclose
    Hi, I have just purchased a Panasonic E85 and while setting it up I have found that I cant get Channel 4 or Sky via its internal tuner, this isn't a major problem as I have it connected to my Sky+ via scart AV2, but I was wondering if anybody new the answer, also is the RF output signal able to be moved, old equipment had a small screw you turned, as it seems to clash with a TV I have in the kitchen on Channel 4 which leads me to think the two problems are the same one, other than that after two days of playing with the E85 it seems fine
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Hold the function button down for 5 seconds, you then get a screen to change the rf frequency
  3. Churchclose
    Churchclose
    Thanks for that, I actual found it in the manual, I was so focused on the gimmicks
