Panasonic E85 and Toshiba x32 questions.
Discussion in 'Blu-ray & DVD Players & Recorders' started by davidcotton, Nov 3, 2004.
  1. davidcotton
    davidcotton
    Aug 5, 2003
    290
    Dorset
    +6
    I've managed to narrow down my buying decision to one of the above two machines. Couple of quick questions though if I may?
    a) How noisy are the two players? Its going in a bedroom where I have to sleep at night and obviously don't want it too loud.
    b)Do either or the above machines (or indeed ANY) dvd/hdd recorders have digital outputs on them? This could very well swing the decision as I want to connect to an external dac (which I already own)and then route thru to amp (only running 2.1, no room for more :( )
    Any other models reccomended? If the hdd IS too noisy then would a combo of the panny e55/sky plus work nearly as well? I'm not intending to record loads but as the video is about to pack up I figured that I'd replace it with a recorder of some sort, oh one last thing, does the panny e55 have digital out?
    Cheers.
    David Cotton
  2. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    Why would you leave it on while sleeping?
    Granted I do most of my archiving over night though!
  3. keithyboy
    keithyboy
    hi
    i've got the Panny E85. The fan/hdd isn't that noticeable unless starting up when switching on or when finalizing dvd's.
    The E85 also has digital out (optical tos-link) and possibly co-ax but i cant remeber off the top of my head at the mo.
  4. skyline32
    skyline32
    Aug 9, 2004
    75
    My RDXS-32 is quite noisy in a living room environment. I wouldn't have it in a bedroom.
  5. SDHoward
    SDHoward
    Nov 1, 2004
    250
    When mine's on it makes about the same noise as my old VCR made when it was recording (or playing).
    When its on standby its silent
    Steve
  6. alicat
    alicat
    Oct 13, 2004
    92
    Get the Toshiba. It is quiet. It also has optical AND coaixial digital outputs (the Panny only has optical) as well as composite (white and red) analogue.
