panasonic e65 set up (please HELP)
Discussion in 'Blu-ray & DVD Players & Recorders' started by den911, Dec 19, 2004.
  1. den911
    den911
    i have just purchased a e65 i thought i would be capable of setting up , 4 hours later and 3 arguments with the wife no luck . in fact it is a total mess and i really need help . i have a widescreen tv with two scart sockets av 1 and av2 , sky digi box with two scart sockets and the panasonic with two sockets . i also have a technics digital amp with optical cable .i have the dvd working .any help would be apreciated thanks
  2. StuBFrost
    StuBFrost
    Dec 20, 2004
    1,602
    48
    Manchester
    +87
    I have exactly the same setup as you and I have also just bought a Panasonic E65.
    The way to set it up is to connect from the Sky TV scart to the Panasonic scart in. Then put a scart from the Panasonic scart out to the TV.
    Make sure that the sky is set to RGB and that the Panasonic is set to RGB and AV2 normal.
    Stu
  3. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +283
    As Stu says...
    Sky "TV" scart to E65 AV2 (Both boxes set to RGB)
    E65 AV1 to Television AV1 (E65 AV1 set to RGB Output)
    Even when the E65 is in standby you can still view Sky.
