Panasonic E65 Query
Discussion in 'Blu-ray & DVD Players & Recorders' started by stuart_day64, Dec 23, 2004.
  1. stuart_day64
    stuart_day64
    I was just wondering is it possible to link the E65 direct to a computer using the firewire port and then create DVDs using Nero or other similar programs. So basically it becoming a computer DVD drive???
    cheers
    stu :hiya: :hiya: :hiya:
  2. den911
    den911
    i do a lot of video editing from pc via my dv output on camcorder i have the e65 and use the dv input but i do not think you can outout to pc .
  3. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    Quite correct. The iLink on the E65 is input only - and even then only from a digital camcorder and NOT from a PC. The only machine with an input/output iLink socket are the machines in the Pioneer range. That said even they will not work with a PC.
    The best all round solution is to get a PC DVD burner as opposed to try and hook up a standalone DVD recorder.
