Panasonic E65 - Playing JPEGS on CD-R/DVD-R?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Adebenchris, Jan 3, 2005.
  1. Adebenchris
    Adebenchris
    I know the Panasonic E65 has an SD slot but will it play Jpegs that have been recorded on CD-R or on DVD-R? Or is it a case of transfering my photo collection on to DVD-Ram via the SD slot? Any advice would be great.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,146
    Argyll
    +2,213
    Fairly sure it will only play JPEGs from DVD-RAM or solid memory (SD Card, Compact Flash etc).
  3. Adebenchris
    Adebenchris
    Thanks Rasczak - helpful as ever. I think I'll take along a sample and try before buying. I'll drop the results back here.
  4. BENSONDOG
    BENSONDOG
    Beware. You can only save JPEGs to DVD -RAM not to DVD-R
