Panasonic E65 connection confusion
Discussion in 'Blu-ray & DVD Players & Recorders' started by Akele, Dec 27, 2004.
  1. Akele
    Akele
    Today I took deliver of a s****y new Panasonic E65 recorder (lucky me :thumbsup: ). After searching this forum for a bit I think I have worked out the optimum connection settings. I have:
    Nokia T221 (freview) AUX --> E65 AV2
    E65 AV1 --> TV AV1
    This all seems to work fine except when I try to set AV2 Input settings (on the E65) to RGB. When I set AV2 to RGB I just get a black screen and audio. When I set AV2 back to video I get both audio and video.
    I'm guessing that I want to have both AV1 & AV2 set to RGB (rather than video or s-video). At the moment I can set AV1 to RBG but not AV2. Does anyone have any suggestions? I hope this makes some sense.
  2. Akele
    Akele
    Oh, for some reason the word s w a n k y has been been bleeped. Anyway...
    Can anyone suggest some good scart leads, and where to get them, to use with the Panasonic E65? I like the look of the QED stuff. I'm guessing that 2 scarts is way to go to get best quality. I'm also guessing that I shouldn't get RGB only scarts as they will give me no sound.
    Any advice you guys can give me is much appreciated. :)
  3. jem
    jem
    Sep 24, 2002
    527
    +7
    This means that AV2 is not receiving an RGB signal. I'm not familiar with Freeview but if it's anything like the Sky digibox, you need to connect the TV out scart to the E65 AV2. I'm guessing that what you describe as AUX is like the Sky VCR scart and this only outputs composite.
  4. Akele
    Akele
    Ah, that fixed it. Many thanks for your help Jem. :)
  5. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Good scarts?
    Get them from TVCABLES online.
    They do a really good flat cable scart for £5.99!!!!! Check it out! I couldn't believe the quality. Don't pay silly money for 'named' scarts unless you're a real audiophile.
    www.tvcables.co.uk/cgi-bin/tvcables/SC001.html
    Jimmy
  6. tony79
    tony79
    Jan 6, 2005
    1,172
    +90
    I have a similar set up in that I have a sony freeviewbox connected via the tv out into the panny av2 and av1 out to the rgb scart on my sony tv. Have been mightily impressed by the machine. Bought mine for £229.99 and consider it a bargain!
  7. noikz
    noikz
    Sep 29, 2004
    519
    +18
    I bought an e65 mainly to route my sky+ into my pwd6s DSUB connection. (and to replace my tired old Philips DVDr).
    I have to leave the recorder on to get component out (does that sound right)?
    I don't mind leaving it switched on but the display only shows "NO DISC" etc and not the clock like when the machine is in standby, which is a little annoying. :(
    The only way I can get the clock on is by toggling the "status" button but that also brings up a large onscreen banner. :rolleyes:
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,146
    Argyll
    +2,208
    Yes - no machine in the world will convert RGB scart to component when off.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    nokiz slap a RAM disc in there so you can live pause etc and that will clear the no disc display (gives you the RAM disc time tho not clock IIRC)
