panasonic e55 recording problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by JOG, Nov 23, 2004.
  1. JOG
    JOG
    Hi, I'm copying old home videos to DVD-R using a dmre55, and with one of the tapes I get copy prohibited cannot record... this is a home video so there CANT be macrovision on it... anyone else had this problem and been able to fix it?
    I've tried smacking the tape of course but it hasnt helped ;-)
    jog1732@gmail.com
  2. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    Noise will be making the E55 think its copy protected. A Macrovision removing cable should work and is perfectly legal in this case.
  3. JOG
    JOG
    thanks... I looked on google for cables, can anyone recommend a reliable one? My concern is that these products might be good at removing genuine macrovision, but not 'noise' that is being mistaken for macrovision by the recorder...
  4. Bosco
    Bosco
    The fact that it can remove macrovision shouldn't prevent you from buying it, you are just backing up a home movie to DVD.
  5. JOG
    JOG
    sure, I understand... but as the tape doesnt actually have macrovision on it, will a product designed to remove macrovision also remove the noise that my panasonic is confusing with macrovision? Just dont dont want to shell out £25 for something that wont do the job...
