panasonic e55 query
Discussion in 'Blu-ray & DVD Players & Recorders' started by sunderland, Jun 10, 2004.
  1. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    was just wondering if anyone has one. and what are they like at playing copied disks. i.e my own disks that i backup.and does anyone no what picture quality is. finally just got rid of phillips 880 and i want something that is reliable thanks.
  2. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,836
    71
    birkenhead
    +74
    first off are you recording from sky digi etc or analogue and ssecondly it depends on what recording quality you have it on.had mine a few months pic quality is fine on copied and pre recorded discs and the menu system is very nice aswell.apart from it being RAM i really cant complain,and if you go to richer sounds you can get a multi region one for 220 quid.
  3. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    i will be recording of sky digi. and like i said i backup a lot of my disks as the kids like to watch them. so playback of copied disk would be needed. thanks for advice
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Can you expand upon what you mean by this? Do you 'copy' your disks to DVD-R, DVD+R or DVD-RW? If so they will play in the E55 provided they have been correctly authored. If you copy your disks to CD-R/-RW in DivX (or other MPEG4 varieties) or WMV then they will not play.
  5. dude1971
    dude1971
    I've had the e55 on loan from Richer Sounds and it's better picture quality than the e60, in my opinion. And you get thumbnails on your recording, which I like.
  6. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    Rasczak i copy them to dvd-r using clonedvd plus i like to play a lot of mp3 files aswell
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    I'm not sure what format CloneDVD pushes the 'copy' out in: I presume (from the name) the DVD-Video standard in which case the E55 should not have a problem playing them. If in doubt take a copy you know works down to your local retailer and ask if you can try. But it should work.
    The E55 will also play MP3s but only, as far as I know, off CD-RW or CD-Rs.
  8. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    thanks Rasczak will do that. do you think richer sounds will let me test it in the machine before i buy.
  9. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    I'm sure they will. I've done such tests in a variety of shops: Comet, Panasonic and Sony shops - so I'm sure if they have a model available they will let you test it.
  10. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    thanks for the help rasczak. will go through tomorrow and see if they will test a few for me.
  11. Tesla
    Tesla
    Dec 9, 2003
    943
    Bristol, UK
    +32
    I have been looking at getting a DVD Recorded and have set on the E55.
    At comet we have it for £300. Even with my staff discount RS still works out cheaper.
    I would get a price match done but the model at RS is region free.
    Anyway, what i would like to know is this:
    Can i create menu structures?
    i.e. I have set up a series link on the footy on my Sky+. If i copied these matches onto DVD could I get a menu to come up upon loading of the disc with say a list or even better thumbnails for each match?
    Do you understand what im asking?
    Thanks.
    p.s. Would the quality between the e55 and sd330 warrant keeping the sd330? see my sig for my kit.
  12. volvofl10
    volvofl10
    Jun 17, 2004
    79
    panasonic E55 at asda is £249 ish but if you know a asda "Colleague/worker" they get 10% discount, so machine is £224.
    only thing is this is in limited stores as a trial
    minworth(west mids) Manchester( not sure which store), Southampton (not sure which store)
    The Panasonic Helpline quoted to me
    "DVD recorders are repaired/warranty like most P.C's , on a collect and return by them basis" unlike other items in there range that have to go back to the seller or panasonic agent .
    hope thats of help.
    Also most Panasonic agents/dealers have a promotion on starting this week,
    £279 and this includes 5 x -r discs, and 5 x Ram discs. still a bit pricey , but at least they are including discs now.. bought mine last week, and no discs was included..... bit like buying a new car with no petrol in it !! nice marketing panasonic :thumbsup: :nono: :nono:
  13. dude1971
    dude1971
    Well I took mine back to Richer Sounds (the e60 that is) and Panasonic replaced it with a new one. However, it wasn't made multi-region so I had to wait for that to be done by RS (good thing I noticed it, they hadn't).
    The e55 is £220 at Richer Sounds btw.
    Regards
    Dude
  14. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,836
    71
    birkenhead
    +74
    or you could get it from richer sounds for £210 it did say the price on the website but now it just has ???? on it.
  15. pgayler
    pgayler
    Dec 11, 2002
    30
    Maidenhead, Berkshire
    I use dvd-cloner to make backups, but they don't play on my E55, yet they do work on my panny RV31, but if i use dvd-cloner to copy the files to my hard disk and then use nero v.6 (nero Burning Rom - option) to copy from Hard Disk to dvd-r they play fine, the quality is as good as the original.
    Hope this helps
  16. volvofl10
    volvofl10
    Jun 17, 2004
    79
    i use DVDDecryptor > Mode iso read to hdd, then > Mode iso write to disc.
    havent had anything not play on pannyE55 yet , using ritek grade a g04, and datasafe A (ritek ink G04) :thumbsup:
  17. runningback
    runningback
    Feb 4, 2004
    339
    Probably has to do with Nero6 the ones i created with nero wouldn't play
    on my e55 either, since i use only dvd-decrypter all plays fine.
    btw, bought mine fromhere
  18. Tesla
    Tesla
    Dec 9, 2003
    943
    Bristol, UK
    +32
    Would i notice the difference between a Tosh 330 and a Panny E55 for playback?
    All used with the gear in my sig.
  19. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,836
    71
    birkenhead
    +74
    by all accounts it is only slightly below the pic quality of a ns900,although i havent done a side by side and i do own a ns900 im pretty sure it would whip a tosh 330 lol.
  20. millstream
    millstream
    I have some questions about the E55:
    I bought it in the UK but live in Sweden where we have channels below 21 which the E55 didn't have. Does anybody know if this is possible to change this thru the software?
    It was also hard to tune in any channels above 21 (found two with bad picture). Is there different PAL systems that are not compatible?
    When hooked up to a digital decorder with RGB and outputting prog scan component to a Sanyo Z2 the pq was not as good as expected, especially with football (go Sweden!). Has anybody else this set up and how is the pq?
    /Anders
  21. cliffg
    cliffg
    Jul 4, 2004
    20
    Just an update on price.
    I phoned RS yesterday - They quoted me £255 for the MR version. PRC direct has this for £249 (no extra for post). Best porice I have found is Digital Point (see http://www.digital-point.co.uk/model.asp?ID=840) which has MR for £225. If yiu dont need the MR then PRC Direct is £215.
    Does anyone have any experience of using cheap blanks with this model. Will it work with anything. Also what about the chaeper DVD-RAM that you can now pick up for about £2?
  22. dude1971
    dude1971
    I use the Smart Buy DVD-Ram which was only £1.49 and it's been fine.
    Regards
    Dude
  23. volvofl10
    volvofl10
    Jun 17, 2004
    79
    regarding cheap blanks, ive only used ritek graded A, GO4, about 50p (uk)a throw, these work fine
    ive only used the same "Smart Buy DVD-RAM" that Dude1971 above has used , and like him i find them fine, i use them for everyday recording.
