Panasonic E55 Progressive and Multi-region
Discussion in 'Blu-ray & DVD Players & Recorders' started by richdutton, Aug 2, 2004.
  1. richdutton
    richdutton
    Apr 19, 2002
    36
    London
    I'm considering buying an E55 but cannot find out whether it does NTSC progressive scan as well as the advertised PAL progressive scan. Does anyone on here know. Also, I know a couple of places will make it multi-region with a "special remote control". Can I do this with a Kameleon, and does anyone know the code?
    Many thanks
    Rich Dutton
  2. HelenS
    HelenS
    Bearing in mind that I know absolutely nothing myself(!) here's a quote from the manual of my new E55 - it might help you decide if it does what you want. It refers to the Transfer section of the Picture menu, when progressive output is turned on:
    "When the output signal is NTSC: Auto1 (normal): detects 24 frame-per-second film content and appropriately converts it. Auto2: Compatible with 30 frame-per-second film content in addition to 24 fps film content. Video: Select when using Auto1 and Auto2, and the video content is distorted."
    There is a separate section referring to the options for PAL (which refers to 25 frames per second only) so hopefully that looks promising?
    Maybe it's only a clue rather than an answer. Can't help with the multi-region part I'm afraid (just a beginner!)
    Helen
  3. richdutton
    richdutton
    Apr 19, 2002
    36
    London
    Sounds good, thanks a lot. I've just found this on Panasonic Australia too:
    http://www.panasonic.com.au/catalogue/details.cfm?pcode=DMR-E55&pdiv=DVDREC&cat=5_1
    "Progressive Scan (PAL/NTSC)
    The Panasonic DVD Recorder is equipped with a high-precision progressive video processor that handles 25-frame (NTSC: 30-frame) progressive scan images (To enjoy a progressive scan picture, a TV with progressive scan capabilities must be used)."
    Looks promising.
    Anyone on multi-region?
