chrisconnew
Established Member
- Joined
- Nov 3, 2002
- Messages
- 69
- Reaction score
- 5
- Points
- 23
- Age
- 45
Currently trying to program the volume control on the remote for my Panasonic E55 to control my Pioneer VSX-511 receiver but with no luck. Had the same problem recently getting the volume control on my Tivo remote to do the same thing - and after trying the listed codes in the manual it was suggested to me (after posting either here or on thedvdforums.com) that i should add 1000 to the code i was using. Hey presto! this worked great but now i'm hoping some bright spark on here can suggest something similar for use on the remote control for the Panasonic E55.
Short of trying all 100 odd codes listed in the manual i don't have any other options.
Any ideas?
Any ideas?
