Panasonic E55 MP3 play order
Discussion in 'Blu-ray & DVD Players & Recorders' started by richdutton, Aug 20, 2004.
  1. richdutton
    richdutton
    Apr 19, 2002
    36
    London
    Has anyone got a foolproof method for coercing the E55 into playing MP3s in the right order? It seems to play them in the order in which they're burned, rather than alphabetically, which is fine for some burning s/w (like Windows Media Player) but bad for others which don't seem to burn alphabetically (like CopyToDVD).
    I know there's a box in the manual suggesting that prefixing files and folders with a three digit number should work but it simply does not. I've also tried short and long file names and have ensured I'm writing ISO 9660 or whatever.
    Ta
    Rich
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,676
    Is it totally unhelpful to suggest burning with software that puts it alphabetically then? ;) Seriously if you can't do this for whatever reason can you not compile the files on your HDD and then drag them to the burning ROM in the order you want?
