Panasonic E55 help!
Discussion in 'Blu-ray & DVD Players & Recorders' started by mepsipax, Jul 13, 2004.
  1. mepsipax
    mepsipax
    Mar 20, 2004
    181
    +8
    Just purchased a Panasonic E55, and need some advice on setup.
    We recently decorated, so had to unplug all the TV stuff (bad move!) - unfortunately we are all stuck at how to set it back up.
    Its really complicated but here goes -
    Have an Argos scart box(splitter?)
    32inch WS TV with 2 scart inputs one RGB
    Panasonic sky satellite digibox
    Sony 1080 receiver
    Xbox
    PS2
    E55 DVD recorder
    Have unplugged the VCR as didn't want to complicate matters further.
    I spent approx 3 hours last night trying different combinations, but couldn't manage to set everything up as it was previously (obviously the E55 being new is the only different part of setup).
    Have searched these forums for help but no luck as yet
    Help appreciated!
    Mepsipax
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,185
    +3,037
    OK try this.
    Attach the splitter to the TV's RGB input (AV1 usually)
    Connect the skybox to the E55 Recorder using AV2 on the back of the recorder.
    Attach the AV1 ouput of the the Recorder to a input on the splitter. To record Sky select AV2 on the recorder and the right input on the splitter. The sky transmission will appear on the TV.
    Attach the X Box and PS2 to the splitter using scart leads. To select each one, choose the right input on the splitter.
    The 1080 reciever will accept digital input from the E55 via a optical digital/phono cable. I don't know what the consoles have.
  3. mepsipax
    mepsipax
    Mar 20, 2004
    181
    +8
    hi
    Thanks for the advice
    Got it working eventually!
    Only thing is I needed the bottom scart on the digibox for my new digisender transmitter - I tried it in every other place, but that is the only place it worked.
    Because of that I am not using the AV2 connection between my E55 and the digibox (bottom scart occupied by transmitter scart as stated above).
    Not sure if this is going to be a problem?
    So far everything appears to be working so fingers crossed!
    Mepsipax
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,185
    +3,037
    Does the skybox have two scarts? It should be attached to AV2 of the recorder using the scart output that would have gone to the TV.
    The second scart (if it has one) is normally used for a VCR. Could the digisender be attached to this?
