Panasonic E55 help...please!!!!
Discussion in 'Blu-ray & DVD Players & Recorders' started by bigpuppy, Dec 7, 2004.
  1. bigpuppy
    bigpuppy
    Newby here
    Can anybody help? :lease:
    I am trying to set up the following:
    Panasonic E55 DVD Recorder
    JVC AV28R250Ek TV with 3 scart sockets
    Ferguson FDT 500 Freeview receiver with 1 scart socket
    Panasonic SC-HT900 DVD Home Theater Sound System
    Can I set it up, can I hell!
    I set it up as shown in the E55 set up and it wont work! When recording using the timer, the TV switches over to the channel I want to record but will not let me view the other channel.
    I have tried all ways and now have no faith in my abilities to sort out.
    Can anybody help me in simple language. It all worked before!!!!!
  2. morgs
    morgs
    Nov 27, 2004
    175
    +3
    Try a thread further down called
    "newbie E55 connection help" or something... (too thick to remember, too lazy to check)
    I got some great advice after I also was foolish enough to follow Panasonic's disastrous instructions
    I've got the same dvd recorder as you, the same tv, but I've got sky+
    I think if you follow rasczak's (sp) advice, you won't go far wrong
    It's worth it in the end, good luck
