Panasonic E55. Compatible discs ?
transwest
Hi all,
am I missing something about my Panny E55 ? For some reason, it doesn’t seem to recognise +R or +RW discs ! To be truthful, I have only used RAM discs for normal use,,, but as I have bought a cheap LiteOn for the Den, I have bought some +RW & +R (Sony & Verbatim) discs,,,, as I thought they’d be usable in both machines.
All ideas will be appreciated.
thanks for looking
TranswesT
ROYOLD
The Panasonic DMR-E55 is one of the older dvd recorders and only supports DVD-R/RW and DVD-RAM. Only the newer models support +R/RW. The native support for DVDR on Panasonic models was always DVD-R. Shame that you purchased a Liteon who's support was for DVD+R.
Delh68
transwest said:
Hi all,
thanks for looking
TranswesT
Mine will read +RW/+R, but that's it.
Delh68
transwest
thanks,,,, yep,,,, I don't know where I got the idea that it used plus discs,,,, might try reading the booklet next time !!!
thanks to all
transwestgroup.me.uk
