Panasonic E55 and 8x media
Discussion in 'Blu-ray & DVD Players & Recorders' started by DVD-RAM, Feb 28, 2005.
  1. DVD-RAM
    DVD-RAM
    Hi All,
    A supplier has erroneously sent me some 8x DVD-R in place of the 4x DVD-R which I ordered.
    Has anyone had any problems with 8x media in their Panny E55?
    I know that Panny recommend max 4x media; a rule I have always adhered to; but 4x media is becoming hard to find.
    Any comments?
  2. HMHB
    HMHB
    Nov 11, 2001
    26,423
    Nottinghamshire
    +5,059
    I think it depends on the brand of media you are using.
  3. novice2
    novice2
    I use 8X verbatim without any problems
  4. DVD-RAM
    DVD-RAM
    Mine are 8x Maxell. Anyone tried them?
  5. clawson
    clawson
    I was sent some 8X when I ordered 4X but so far (about 12 discs into 100) I haven't had a problem on the E55 - these were Ritek G05 dye printable 8X discs.
    Cliff
  6. DVD-RAM
    DVD-RAM
    An update on this, I spoke to Panasonic, and they said 8x media (its actually 1-8x media) is fine.
    Thanks for all of your input.
    My Maxell discs are OK so far.
