S
sandy2011
Bit of a weird one this
Basically, have the e50 connected up to the following:
AV2>Tivo on scart connected via scart to a Pioneer freeview box
AV4>Panasonic S75 DVD player via s-video
E50 output>S-Video & optical connection to my amp
What's happening is that when I put a dvd in the s75 and switch the e50 to the av4 input, the picture comes up but has a black/blue/green bar at the bottom of the screen about 30mm high. If i spin a disc in the e50 then it plays no problems, but as my S75 is multi-region, i can't play my ntsc discs in the e50.
I've checked the cables and eliminated them (all brand new ixos s-video) so what could the problem be? I've been into the setup on both machines and can't find anything out of place.
Also does anyone know if it is possible to change the remote control settings one of the machines so that both don't use the same signal?
Sandy
Sandy
