Panasonic E50/E60 music recording
Discussion in 'Blu-ray & DVD Players & Recorders' started by bowler, Oct 16, 2003.
  1. bowler
    bowler
    Jun 8, 2003
    223
    I believe the E60 has greater music recording capabilities than the E50.
    Has anyone compared the two and is there a noticeable difference?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    Yes that's correct. The E60 allows you to record in LPCM when recording in XP mode. The E50 does not. This is ideal for concerts etc although the 1 hour's recording time isn't brilliant! The HS2/E100 have the same feature but obviously you can record for much longer in XP mode on their respective HDDs.
    In all cases the picture bitrate is dropped (slightly) to compensate for the greater data rate used on the audio - so only use this feature for recording music where sound matters!
