rowbos
Established Member
I have got problems with my setup which is currently configured as follows...
NTL Digital AV1 (TV) output to TV AV1 RGB input.
DVD AV1 output to TV AV4 RGB input.
NTL Digital AV2 output to DVD AV2 connection.
DVD AV1 and AV2 set to RGB and AV2 mode set to decoder, input select on the DVD set to A2 (if I select A1 then I just seem to get the inbuilt tuner rather than AV input).
The problem is that I can watch NTL Digital via my AV1 input on the TV, I can watch pre-recorded DVDs via AV4 input on the TV, but when I record - or just select AV4 on the TV without pressing play - ie I am connected to the DVD and can navigate the menus etc - I do not get my NTL digital picture to watch/record...
Edit - No picture - But I do get sound?
I used to have NTL daisy chained via the DVD to the TV AV1 input - which all worked fine - but it had the problem that I could not record anything off either terrestrial or digital sources without watching the same program.
Probably something really stupid but its late and I need some help!
Thanks,
Steve.
Thanks,
Steve.
