Panasonic E30 & Tivo owners
Discussion in 'Blu-ray & DVD Players & Recorders' started by alex f, Jan 3, 2003.
  1. alex f
    alex f
    Sep 5, 2002
    63
    Reading UK
    Does anyone with an E30 and Tivo know if I could record a home video to the E30 Ram, edit it and then send it to the Tivo hard drive and then play it back to the E30 and burn it onto DVD-R?
    I have a brand new Tivo on order and it has just arrived and I only want to collect/buy it if the above can be done.
    Many thanks for your help.
    alex
  2. jont
    jont
    Apr 8, 2002
    4,197
    near Aylesbury
    +528
    Yes you can send an RGB analogue signal thru the tivos scart socket and record it as a manual recording onto the HD ...
  3. alex f
    alex f
    Sep 5, 2002
    63
    Reading UK
    Cheers Jont.
    I'm getting to the point of not being able to justify this much av kit to the missus..........anyway must go get a Tivo.....
  4. Fuel Crusher
    Fuel Crusher
    Nov 24, 2002
    104
    16
    UK
    Hi Alex f,
    I have been doing what you describe, see my layout attachment.
    I placed my E-30 inbetween the sky box and tivo so that I could record from either without having to mess with cables. To record back from tivo to E-30 you just need to make sure the sky box is off and the E-30 input is set on Video not RGB.
    To be honest though this method is not the best as the Tivo recording quality is not a patch on the E-30, so expect loss. This is why I've recently bought an RA-82 player to play back edited ram discs to my E-30, works much better and retains quality.
    Paul.
  5. alex f
    alex f
    Sep 5, 2002
    63
    Reading UK
    Sounds good Paul but I can't afford anything more than the Tivo (£145 brand new). This is all going through a plasma (with no scart inputs, just rgb to vga) so high quality is prefered.
    Is tivo that bad? My video is!! Everything else in my system is giving an excellent picture. I have my very last chance to buy a brand new tivo tomorrow so I need the advise please.
    Many thanks
    Alex
  6. jont
    jont
    Apr 8, 2002
    4,197
    near Aylesbury
    +528
    The picture from the tivo should be significantly better than your video ... if you are just using the tivo as adump disc from the e30 then you can use the 'best' quality ... it will suffer some loss due to going through a few dig/analogue/compressions but should be more than acceptable compared to 2nd or 3rd generation video ...
    rgds
    Jon
  7. Fuel Crusher
    Fuel Crusher
    Nov 24, 2002
    104
    16
    UK
    Alex,
    TiVo is still much better than video tape but in my eyes suffers from pixellation more than the E-30. For example on the E-30 the XP and SP settings are just about broadcast quality and as you lower the setting to LP and EP the quality worsens by the picture becoming softer and colours weaker. With the TiVo even on best quality the picture looks digital and as you lower the quality it worsens by the picture getting blocky, pixillating.
    When I have recorded from E-30 to TiVo there is a very noticable difference. When I have recorded from TiVo to E-30 the picture looks identical.
    This may sound like I don't rate the TiVo but this is far from the truth, whereas I could live without it I wouldn't want to purely for the convienience it provides, and thats with it's manual recording feature as I don't subscribe. But if somethings on that I want to keep it goes on Ramdisc not Tivo.
    Paul
  8. alex f
    alex f
    Sep 5, 2002
    63
    Reading UK
    Cheers Paul & Jon,
    I just want to record about 10min sections of home camcorder and edit it, tape to dvd that I could send to relatives and/or archive.
    No-one can play ram so it would have to go to dvdr, I could edit on the camcorder but its not that good which is why i thought the tivo would be best.
    What do you think, worth getting or not for the above reason? I've only just got the other half over the shock of the rest of the system, all of it less than 6 months old so I'm pushing my luck with her as it is lol
    Alex
  9. Fuel Crusher
    Fuel Crusher
    Nov 24, 2002
    104
    16
    UK
    Alex if this is the only reason you are buying the TiVo then I wouldn't bother and spend an extra £40 on an RA-82, this would give you much better quality results. The only downside to this method is the RA suffers a slight pause on edit points, so I either insert a static image or just a blank screen on my edit points or I make them seperate chapters.
    If you are not that fussed about retaining the best quality and think you may also use the Tivo as it was meant to be used, which is great and a reason to buy one in itself, then go with the TiVo.
    To be honest my advice would be to buy the TiVo and try it out, if you don't like then flog it as there is a strong second hand demand growing, if it suits then keep it. This was my intention but even though it didn't give me the quality I desired I've still kept it and bought the RA as well, so I understand the stress the other half can give :D
    Paul
  10. alex f
    alex f
    Sep 5, 2002
    63
    Reading UK
    OK, thanks for that info but I can't find any sites with the RA82 in English anywhere?
  11. Fuel Crusher
    Fuel Crusher
    Nov 24, 2002
    104
    16
    UK
    I bought mine from www.be-direct.co.uk for £185 I believe it's the only panasonic player that supports dvd-ram apart from a few expensive portable units.
    Paul
