Panasonic E100 Black Screen
Discussion in 'Blu-ray & DVD Players & Recorders' started by Penryn, Jan 13, 2004.
  1. Penryn
    Penryn
    Dec 12, 2003
    3
    I wonder if anyone has experienced this problem with the E100. I recently got mine and it is connected up per the manual for Sky RGB - no RF used at all - only the digibox.
    On some recordings, I get a black screen but the sound is OK. I tried it last evening and it was recording fine but when I checked about 10 mins later, the screen was black again. I pressed Time Slip, the picture came back again and remained for the remainder of the recording time.
    Thanks in anticipation.
  2. johnjackthom
    johnjackthom
    Sep 20, 2001
    747
    Northumberland
    +283
    This sounds like it could be the Sky box dropping its RGB output.
    For some obscure reason pressing the TV button on the Sky remote has this effect, resulting in only composite video on the digibox TV scart!
  3. Penryn
    Penryn
    Dec 12, 2003
    3
    I should have mentioned that I have tried two digiboxes, a Thomson and a Panasonic 30. I get the problem with both. What you say makes me wonder though, maybe it's the cable. I'll change it and see if it makes any difference
  4. Penryn
    Penryn
    Dec 12, 2003
    3
    I've just re-read your post and it's dawned on me what you are saying! I use the Sky remote to control the TV and AV2 on the TV is served by a Humax receiver. As the TV only has one RGB scart, of course I have to press TV on the Sky remote to enable me to view the Humax (composite) output on the TV.
    I shall be very surprised if you haven't found the solution.
    Very many thanks.
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Use the tv remote at all times, I have disabled the tv button on my digibox remote to stop this ever happening again.
    If you use the tv button to put the tv on standby and leave the recorder to do a timer recording you end up with the black screen
