hodg100
Outstanding Member
- Joined
- Aug 8, 2005
- Messages
- 14,220
- Reaction score
- 4,522
- Points
- 6,489
Hi PaulGreat review as ever.It seems Panasonic haven't kept the formula of the wonderful CX680B with it's replacement. A shame.
Out of interest, why are you using a peak white of 140 nits now? Weren't previous reviews (the ones I've read at least) aiming for peak white at 120 nits (or cd/m2)?
Cheers,
Paul
Scratch that, I can see Panasonic have a DX650 this year which I expect is the replacement for the CX680.
Cheers,
Paul
Does this set suffer from the 50Hz bug? I have the 40DX700 and it is plagued with it (sudden spontaneous judder even when all processing is turned off). The only way to get rid of it is Game Mode but you can't select that when using the built-in tuner, catchup services or playing files.
If not I'll get it swapped out for a 40DX600. I don't care about HDR as it's badly implemented on the DX700 anyway. As I only want a 40" set, I'll still get a VA panel (probably the same one).
