Panasonic DX110
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mattconfused, Aug 14, 2002.
  1. mattconfused
    mattconfused
    I know this is an older model, and i can't find ANY reviews or information about it, but am thinking of buying anyway as it is 3ccd, has dv in/out and i can get it for £899. Is this worth it? Any advice, recommendations or reviews appreciated......
  2. mattconfused
    mattconfused
    So BASICALLY what i'm asking is.... in terms of picture quality is the dx110 the best i will find for under £1000? or will much newer but lower spec models have caught up in the last couple of years?
  3. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
