Panasonic DX100B
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by GlenGill, Sep 9, 2005.
  1. GlenGill
    GlenGill
    Just bought a very secondhand one of these 3CCD camcorders, but no Instruction book. Any advice most gratefully accepted!
  2. Roy Mallard
    Roy Mallard
    Good wee cams them, f1.6 through the entire zoom range, a pretty rare, but very useful thing.
    It's go manual everything just about, although the audio is staged levels rather than fluid control, but at least you have the option of manual control.
    Do a google for that, the DX110 or the EZ30 EZ35 and you might get a .pdf of the handbook.
    I've got one for the EZ35 (operationally exactly the same) but I've not got time to scan it all. That said if you have specific questions I should be able to help.
  3. GlenGill
    GlenGill
    Many thanks for your quick response and helpful advice. I eventually went to Panasonic's site and found I was able to download the booklet from there (88 pages). So that problem is solved. Now to spend a few days studying it! I already find I need a remote control for it VEQ1995). Panasonic don't seem to do one now, so any ideas where I could get one - or its equivalent?
    Thanks again!
  4. GlenGill
    GlenGill
    I was wrong! Panasonic still do one at about£23.
